New 2013 Acura MDX pulled to the left
I bought the 2013 Acura MDX tech 2 weeks ago. I noted the car pulled to the left. How could a brand new car has alignment problem? DO you think there are some bigger suspension problem?
Air pressure not set correctly in one of the tires, alignment out of adjustment from the factory, or a pot hole or something was hit while on a test drive or make ready inspection. You may have hit something and not realized it.
Could also be the road you are driving on and the crown in the road. It's a 2013, the dealer will take care of it for you. No need to panic about suspension problems until you actually have some idea of what is happening and why.
It the car is in alignment try swapping the tire from left to right. If it pulls to the right after that then there is a bad tire. I assume it should be under warranty unless you have had the car for a while. They would probably say you hit a pot hole and damaged it if there too many miles
Zonian22
Nov 14, 2015 01:20 PM
Zonian22
Sep 2, 2015 08:19 AM
