Mirror Position when backing up
Old Oct 16, 2012 | 08:59 AM
Scotch MDX's Avatar
Question Mirror Position when backing up
Hi All,
After I got my 2nd service done I notice the side mirrors auto position when I back up my car. I really like that feature but after 2 weeks now when I back up my 2011 MDX I don't see the mirror auto position while backing up.
Is this a known issue?
If not what should I do to fix it?
Appreciate your help.
Old Oct 16, 2012 | 11:04 AM
RonC5's Avatar
Rocket Scientist
Are you are referring to the outside mirror adjusting down while in reverse? If your mirror switch is in the neutral position, the mirrors stay set as normal, if your switch is moved to the passenger side, the passenger mirror will adjust down when put into reverse, same for the drivers side.
Old Oct 16, 2012 | 11:22 AM
Scotch MDX's Avatar
LOL @ me.
Ok I will check that tonight
Old Oct 17, 2012 | 12:49 PM
Scotch MDX's Avatar
Thank you Ron It worked. Cheers!!
Old Oct 18, 2012 | 09:00 PM
myzsuk303's Avatar
Originally Posted by Scotch MDX
Hi All,
I have similar problem with my 06 mdx, but the mirror used to lower itself when im in reverse but now it just lowers a touch rather than its normal distance. Is that a sign that the motor in the mirror is bad? but when i do it manually it works fine all the way down.
Any ideas?
thanks
Old Nov 8, 2012 | 07:15 PM
TLtrigirl's Avatar
3G TL/2G MDX Owner
Any ideas?
thanks
yes. the motor is going bad. i had this happen on my 09 on the driver's side mirror. it would intermittently: 1) work fine, 2) tilt a tad, or 3) not work at all. i've even had the passenger side replaced as well except the mirror stuttered when it returned to the set position once shifting from reverse.
this has also been the cause of the key fob occasionally NOT talking to the car when unlocking to adjust or tilt the steering wheel per driver one settings. the mirrors, seat setting, and steering wheel tilt feature are all on the same circuit. so if the key fob unlocks the car, but the driver seat/mirror settings do not adjust accordingly, they most likely there is something goofy going on. my dealer has found that the door mirror actuators failing causes this "lack of communication" to the car. so far since i've had both mirrors actuators replaced, key fob is talking to the car fine. it's only bee a few days. time will tell.
Old Nov 9, 2012 | 12:57 PM
arpz's Avatar
Any ideas?
thanks
My 06 does the same thing. Try adjusting the mirror down as far as it goes and it should start tilting in reverse again. Its not a permanent fix though, after a while it stops working again and so I have to keep adjusting it from time to time.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
dre707
Sep 8, 2015 08:32 PM
