Mirror Position when backing up
Hi All,
After I got my 2nd service done I notice the side mirrors auto position when I back up my car. I really like that feature but after 2 weeks now when I back up my 2011 MDX I don't see the mirror auto position while backing up.
Is this a known issue?
If not what should I do to fix it?
Appreciate your help.
Rocket Scientist
Are you are referring to the outside mirror adjusting down while in reverse? If your mirror switch is in the neutral position, the mirrors stay set as normal, if your switch is moved to the passenger side, the passenger mirror will adjust down when put into reverse, same for the drivers side.
Scotch MDX (10-16-2012)
Ok I will check that tonight
Hi All,
Any ideas?
thanks
3G TL/2G MDX Owner
I have similar problem with my 06 mdx, but the mirror used to lower itself when im in reverse but now it just lowers a touch rather than its normal distance. Is that a sign that the motor in the mirror is bad? but when i do it manually it works fine all the way down.
Any ideas?
thanks
Any ideas?
thanks
this has also been the cause of the key fob occasionally NOT talking to the car when unlocking to adjust or tilt the steering wheel per driver one settings. the mirrors, seat setting, and steering wheel tilt feature are all on the same circuit. so if the key fob unlocks the car, but the driver seat/mirror settings do not adjust accordingly, they most likely there is something goofy going on. my dealer has found that the door mirror actuators failing causes this "lack of communication" to the car. so far since i've had both mirrors actuators replaced, key fob is talking to the car fine. it's only bee a few days. time will tell.
Any ideas?
thanks
Any ideas?
thanks
rockyboy
08-04-2024 10:35 AM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
dre707
09-08-2015 08:32 PM
