MDX A/C blows hot air only
I am trying to fix air mixer motor on 2006 MDX. I removed the air mixed motor module and was able to move the levers manually. This fixed the problem and I was able to get cold air so I didn't replace the module. After driving for a couple days, the system started blowing hot air again. I was thinking that the levers moved, but now regardless of the position levers, only hot air blows out again. Any ideas?
Acura Love
It may be your A/C Clutch Relay causing your problems, but most definitely you are low on Freon. I just delt with the same problem this week. I had to replace the relay and the Front motor assembly. My A/C still blew hot on the driver side until I recharged the system. Good Luck
