Loosing power steering after pump was replaced...
Hey, I just got my rack and pinion and my power steering pump replaced in my 2001 MDX. I seem to be loosing the power steering periodically, makes it very hard to turn left or right at slower speeds or when I'm turning after being stopped. Could it be the remanufactured pump was bad? I've heard Acuras have issues w/ after market pumps...
That or there is air getting into the system. Look into the power steering reservoir after driving for a bit and see if there are tiny bubbles in it. Do you hear any whining noise while turning?
Did you use the honda power steering fluid?
Yep, we use Honda specific fluid. We had a friend do the work. He said if it's hard to turn both ways, it's prob a bad pump. If it's tough just one way, it's prob a bad rack.
Ok, so we got a new pump and he replaced it about an hour ago. I drove it for 30 min, taking as many slow turns as possible and it seems to be much better. We'll see. He said the fluid leakage looks like engine oil and not ps fluid. It's not coming from the same spot as it was before the rack was replaced. As for the clunk in the front left wheel, that is pretty pronounced now.
ahh, i wish i could inspect this car in person!
Just do it ..
There is air getting into the system. Check/replace the o rings at the power steering pump. Also, I recall getting the o rings from Honda vs local part store. The local part store didn't fit correctly like the OEM and still allowed air in the system.
I know... I guess I was not clear. Im not sure if this is an aftermarket PS or rebuilt OEM PS. What I meant is that the O-Rings should be OEM and not aftermarket.
I've bought the aftermarket O-rings from autozone and it still let air in. Only fix was to purchase PS pump o-rings from Honda/Acura.
Rack Leaking after Pump Replacement
Hi, new to this site since I have not had issues with our TSX(first one now). 2006 tsx with 60k, and the PS pump was making a really bad moaning sound over the weekend. Since we needed the car and could not wait, I replaced the pump with a after market pump from autozone. it fixed the noise, but the steering seemed a bit hard at times during the test drive.
Well, i went out in the garage to take kids to school, and there was a fluid leak, thought, bad pipe, but no, it's from the driver side boot of the RP. Could have my after market PS pump caused the seals to go? I tried to save time and money, but maybe not meant to be. I put in the PS fluid which was made for Hondas.
Thoughts or comments on this and if anyone else has experienced the same? TY
guyenacurazine
04-28-2016 03:29 PM
