Limp Mode no Codes!
Old 03-07-2014 | 05:29 PM
vega27's Avatar
7th Gear
Limp Mode no Codes!
HELP!!!!!
We changed the head gasket on my 04 MDX with about 115k. It drove fine for about a week then all of a sudden, limp mode. I turned it off for a couple of minute, it worked fine to get me where I was going. The next day start up cold - ok. Driving home from work (30 minute drive) 20 minutes in limp again. It's not throwing any codes. I tried to reset the ECU. the battery is charged. I am checking to see if the timing slipped, but that's after that I'm stuck!
PLEASE HELP!
Old 03-07-2014 | 06:08 PM
Majofo's Avatar
Just to be sure, when it goes in limp mode, is it staying in low gear and not allowing you go over 2.5-3k RPM?
Old 03-07-2014 | 07:12 PM
vega27's Avatar
7th Gear
Yes. I can feather the throttle and it will change gear.
Old 03-07-2014 | 10:30 PM
Majofo's Avatar
limp mode won't allow you to change gear, it'll hold you in first and won't allow you above a certain rpm. You have something else going on. Best case, throttle body side, worst case, timing being pulled. Check the connections to the throttle body and app sensor, if everything looks good, take it back to the shop who changed your head gaskets and let them fix it, at their expense.
vega27 (03-08-2014)
Old 03-08-2014 | 08:23 AM
vega27's Avatar
7th Gear
I'll check that today. Thanks!
Jamus22
06-11-2023 11:08 AM
MilanoRedDashR
10-02-2015 11:49 AM
hashbrown
09-29-2015 01:13 PM
thegipper
09-28-2015 02:01 PM
shawnafoxx
1G RL (1996-2004)
09-28-2015 01:33 PM
Quick Reply: Limp Mode no Codes!
