I-009: Obtaining radio code
somebody should kindly help me with tips on how to retrieve radio code for acura radio with serial number.i need radio code for this acura radio navigation serial 30008140.Please help.THANKS
I recently went through this. Calling the dealer was NO help. They said I'd have to bring it in and pay $80 for them to remove it to get to the serial number.
Some googling let me to the answer.
Hold down 1 and 6 on the radio, as you power the car on. Some numbers will come up. Write them down. The digits (not letters) are your S/N.
Then go to the acura website, where there's a link to get your code if you enter the VIN and S/N.
Hope that helps.
-Shawn
Hope that helps.
-Shawn
still need the sn for the radio and navigation. my mdx just died last week and the radio is fine but the navi needs a code for some reason. nothing else died in my car. anyways, i went to acura.com and tried to retrieve my code but it still requires sn for the radio and navi. anyone find another way. i don't really want to take my navi out just to get the sn. please help
MDX code
The only way I know to retrieve the code without taking it to the dealer is online. Get the SN for the radio as stated above, the NAV code you have to get the serial # from the dvd drive under the passengers seat. Its pretty easy to take out there are only two screws. Once you get that enter it online and it should give you the codes.
Trolling Canuckistan
Check the glove box and the engine bay fuse box for stickers with the sn on them. When the cars are delivered to the dealers from Acura, they come with 2 sets of stickers for the radio code/navi code card. Many dealers will put the extra stickers in the glove box or on the inside of the fusebox cover in the engine bay.
If Acura tries to charge you for retrieving the radio code, call the Acura client services number, corporate will go apeshit. They can and will charge you for labor to remove the radio/nav to retrieve the serial number, but if you have the sn and can prove the car is yours (bring your registration) they should retrieve the code free of charge.
Typically they either stick it to the outside edge of the glove box / engine bay fuse box / near battery or in your owner's manual packet. It should be a white sticker with two numbers, the one on the top should be your radio code.
If you do have the stickers and the codes aren't marked Navi or radio remember that radio codes only use the numbers 1 through 6 (b/c it is entered via the radio preset buttons) Navi code uses 0-9 and is either punched in on the navi sceen for touch screen navi or dialed in via the interface dial for non touch screens.
Call the dealer where it was purchased and they'll be able to give it to you
I bought a 2006 MDX today (picking up tomorrow), and this is the first thing that I will do.
dirleton
Aug 6, 2024 08:19 PM
Jamus22
Jun 11, 2023 10:08 AM
