Help!!! Spill in door
Old Sep 29, 2014 | 06:57 PM
Laznancy's Avatar
My daughter spilled a large cup of water in the front passenger door cup holder area. When she went to wipe it up, it was not there. Does anyone know where it went? When I swing the door, I do not hear any sloshing around?
Did it drain out outside of the car when we were moving or is it still in the door panel?
It was only water but I am worried that it may damage something.
Any suggestions??
Old Sep 30, 2014 | 07:42 AM
mrgold35's Avatar
mrgold35
I'm just guessing; but, I hope Acura anticipated spills since the door has a built-in cup holder. I figure it drained out without damaging any electrical parts or rusting issues down the road. Just a SWAG. I really don't want to test this out in my vehicle.
Old Sep 30, 2014 | 07:52 AM
if you really really want to check for damage, take the door panel off and inspect
Old Sep 30, 2014 | 08:15 AM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
The window regulator and door lock actuator are typically mounted above the door cup holder. So in theory you should be fine.
Otherwise as justin said pull the door panel and look.
Old Sep 30, 2014 | 10:30 AM
db22's Avatar
Tip a gallon into the door cup holder area and then measure how much drips out. If it's not a gallon then you know how much the door holds!
Old Sep 30, 2014 | 11:32 AM
NBP04TL4ME's Avatar
soupi
14
Nov 15, 2015 11:15 AM
BIGxRED
Oct 19, 2015 10:47 PM
chiu0nthls
3G MDX (2014-2020)
Sep 28, 2015 03:46 AM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
ceb
ILX
Sep 27, 2015 10:56 AM
