Cruise Control Issue?
Old Oct 24, 2011 | 01:10 AM
T_R's Avatar
T_R
Hey Everyone, i just purchased a 2007 Acura MDX. The cruise control Set and Resume button on the steering wheel works intermittently.
I turn on the Cruise button on the dash with light.
Then I press the 'Set' button on steering wheel, some time it engages the cruise other times it does not. Whats the problem?
Old Oct 24, 2011 | 12:09 PM
Rexorg's Avatar
Sounds like the switch is worn out on your "used" MDX. If you did not buy it certified from an Acura dealer then it's an relatively expensive fix unless you can find a dealer to work with you.
Old Oct 24, 2011 | 12:36 PM
DoctorTuna's Avatar
Definitely sounds like a problem for the dealer to look at, hopefully nothing too expensive, but I have not come across that problem before. I would be less that enthusiastic in even using the cruise control with that problem, especially if it decides to intermittently NOT turn off....
rockyboy
Aug 4, 2024 10:35 AM
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
spoiler900
5G TLX Photograph Gallery
Sep 11, 2015 09:39 PM
