Catalytic Conveter replacement question
Old Aug 7, 2016 | 01:29 AM
23109VC's Avatar
My 2007 MDX has thrown a check engine light related to one of the catalytic converters. My mechanic explained it was not able to be replaced with a "generic" brand due to CA smog CARB rules and that I had to buy an OEM one from Acura...the whole bill parts and labor was going to be about $900.
seemed high to me for one cat. I honestly wondered if any smog person would hoenslty be looking up under my car to see if I had a CA CARB cat or an aftermarket one.. as long as one is there.... maybe they really check fro this nonsense....
I was curious if you guys think this bill is a rip off or is this what I should expect to pay?
if you need additional info, let me know.
thanks for any help you can provide!
Old Aug 7, 2016 | 01:54 AM
Skirmich's Avatar
It all depends on the facility you are going to.. Some are very thorough, some others don't really check for anything but emissions only.
I live in a place where they almost take your DNA as part of the test... So here its OEM or you are F***.
Old Aug 9, 2016 | 10:42 PM
csmeance's Avatar
you can buy aftermarket and have some issues with passing. RV6 makes high flow cats for the MDX that are $400ish and you should be able to pass.
Also have you tried using a can of seafoam in your gas tank? Usually that helps clogged cats
Zach St. Denis
Jul 19, 2016 11:14 AM
