Break-in Procedure?
Old Aug 2, 2010 | 09:23 PM
sammietime's Avatar
Break-in Procedure?
I can't access a MDX owner's manual, so I thought to ask folks here. I'm planning on traveling from Twin Cities Mn to Chicago to purchase a new MDX and then plan to drive it back approx. 330 miles. Is there a recommended break-i procedure? Will this be detrimental to engine? Should I just have it transported back instead? Thanks!
Old Aug 10, 2010 | 11:27 PM
VQPower37's Avatar
people are pretty divided on the break in issue ... some say drive it hard so everything will mesh together each other very well from the get go. others say go easy on it for the first 1000 miles then drive it hard.
i personally think if you just take it ez on the drive home you should be good. try to keep the speed around 55. i dont think the drive will affect the life of your engine much if any
Old Aug 11, 2010 | 08:13 AM
007Acura's Avatar
don't keep the engine at a constant speed
Old Aug 11, 2010 | 10:20 AM
HenryNYC's Avatar
Still a Noob!
If you want to go by the books. All it says is no hard take offs for first 600 miles. Does not mention anything about how slow or how fast you should/can go. Personally, I just drive normal and keep the speed within 60 on highways and vary it up and down by 10mph. No jack rabbit takes offs is for sure.
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
ceb
ILX
Sep 27, 2015 10:56 AM
mc1114
Sep 11, 2015 05:50 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
iRaw
ILX Photograph Gallery
Sep 10, 2015 12:29 AM
