Awd light
autozone readers usually read only check engine light, not awd or airbag or other systems. More than likely it is a bad wheel speed sensor, but you'll need a mechanic with the right scan tool to help you figure out which one. I've used Bluedriver ($99 from amazon) and it gives AWD and other codes on your phone.
SH-AWD Light
OK, did that. Found out its my left rear speed sensor. Any idea if that something I can clean or just replace. Also, some say I should change the hub as well.
ANY HELP IS APPRCIATED!
Acuraoemparts has the sensor for around $40, use coupon code acurazine for 5% off. It's under the parts-> Chassis -> Rear lower arm.
Ordering the parts now. You have been so helpful! So just today my navigation said "Check Disk "Unformatted". Then worked after I shut the car off and restarted it. Would you know anything about that? Thanks again!
dvd drive could be failing and they are not cheap to replace, alpine can refurbish them for around $500 last time I looked into it.
Oh great!
blhokie
3G MDX (2014-2020)
Mar 2, 2018 03:51 PM
Rahul
Jan 14, 2007 03:39 PM
sequoiagrapeboy
Sep 9, 2006 04:19 PM
