Acura MDX suspension
Moderator Alumnus
I have been searching for MDX lowering springs for a while now and haven't come up with much. I wonder if anyone knows if the 1st gen (01-06) MDX share its suspension or springs/struts with any other vehicle in the Honda/Acura lineup?
Thanks!
Thanks!
Master MDX Driver
The MDX closely shares similar parts and accessories with the Honda Pilot. No other would be close. The hardest part about matching parts up is that Honda changed the Pilot all around design ahead of the MDX. Essentially the framework for the 2nd Gen MDXs has existed in the Pilot for a few years now. For Example: (I hope this makes sense; it did in my head :p )The 01-06 MDX has the same starter, Only the 03-05 Pilot uses that same starter. The Pilot 06+ Models uses the 07+ MDX starter. Anyways, I assume it would be the same as the suspension system.
Moderator Alumnus
you could always get a set of koni shocks and cut a coil off the stock springs...
Moderator Alumnus
I've haven't had any luck with finding any lowering springs either. I also think it would look better a little more dropped. I thought it was dangerous to cut springs? I don't think I would go that route.
Lots of JDM parts on my
I definately wouldn't cut springs. A lot of people go that route w/ vehicles with little aftermarket support. You could always go with a custom airbag setup.
Hellwig carries a product that is suppose to drop a vehicle by compressing the spring. I dunno about that deal. lol.
Moderator Alumnus
Moderator Alumnus
KW makes a coilover set up for the Honda Ridgeline that lowers that vehicle. If the suspensions between the two cars are similar maybe you could use that.
http://www.andysautosport.com/honda/...u00147314.html
Evil Teo
3G MDX (2014-2020)
14
08-16-2020 04:29 AM
