2013 MDX cricket noise
Old Dec 15, 2019 | 07:05 PM
nonezone's Avatar
4th Gear
After driving on highway for almost 20 minutes, there is a small noise like cricket singing, but I can not tell where it comes from. Any idea for this? And it is a 2013 MDX, base model.
Old Dec 16, 2019 | 08:39 AM
AcuraAddicted's Avatar
It would be really hard if not impossible to diagnose this remotely using description of the sound.
Can you record the sound?
Does this sound appear only when driving, or when parked with the engine running as well?
Does the pitch change with RPM?
Old Dec 16, 2019 | 02:03 PM
hub or axle would be my guess
Old Jan 12, 2020 | 12:44 AM
elrifas's Avatar
Had a similar problem, mine was a loose bolt on a bracket close to the alternator.
Old Feb 14, 2020 | 10:14 PM
nonezone's Avatar
4th Gear
Had to go to the dealer, and replaced the propeller shaft.
Old Feb 15, 2020 | 10:59 AM
djtsmith007's Avatar
ElectroMechanicalEngineer
How much did they charge? There are quite a few forums discussing this noise coming from the bearing mid way on the propeller shaft. Last i looked its still about $700 for the shaft since you cannot get the bearing replaced alone.
Old Feb 15, 2020 | 10:28 PM
nonezone's Avatar
4th Gear
Pretty costly, around $1500, including diagnosis. Have to say, the reliability of Honda is going down. May try another brand for my next car.
Old Feb 16, 2020 | 10:31 PM
Wow. The propeller shaft only costs $700. What's the rest $800 for? It takes about half an hour to swap the propeller shaft, just a matter of unbolting the old one along with the protector and bolting the new one in.
mjwill99
3G MDX (2014-2020)
Apr 5, 2026 09:40 PM
Sparky1951
3G MDX (2014-2020)
22
Dec 5, 2020 10:34 PM
SipsAcura
3G MDX (2014-2020)
Feb 27, 2019 07:43 AM
Waldo73
3G MDX (2014-2020)
Jun 21, 2018 10:38 AM
Brad Mower
3G MDX (2014-2020)
14
Sep 15, 2015 07:54 AM
