2012MDX Coolant Leak
Old Jan 24, 2022 | 04:24 PM
rah11h's Avatar
I started to see small drops of coolant on the garage floor every now and then. Got under vehicle but could not find the source. Tried pressure testing the coolant system. The only place I see coolant is at the seam of the oil pan at the corner near the oil drain bolt. I do not see coolant above this point. Where could the coolant be leaking?
2012 Acura MDX coolant leak
Old Jan 24, 2022 | 04:45 PM
mrgold35's Avatar
mrgold35
I can't tell exactly where the picture was taken. The prime suspect would be the water pump. The water pumps starts to drip drip drip when it is about to go out.
Old Jan 24, 2022 | 04:54 PM
altair47's Avatar
That's right, it looks like the water pump is leaking. How long ago did you change the water pump? There is a possibility that your entire timing belt is in antifreeze and may break because of this.
Old Jan 24, 2022 | 05:22 PM
rah11h's Avatar
I did the complete timing belt service last April.
Old Jan 24, 2022 | 05:38 PM
altair47's Avatar
So you yourself answered your own question, unfortunately your new water pump is garbage.
Old Feb 6, 2022 | 07:57 PM
acuratech481's Avatar
My guess is aftermarket water pump in that case. They ALL leak. The gaskets aren't thick enough. Honda or nothing, better off with an original pump lol
Will Hubbard
Jul 12, 2017 12:27 AM
duvaL32TL
1G TL (1996-1998)
Feb 5, 2007 07:35 PM
49er
Oct 8, 2006 01:00 AM
732xghost
Sep 21, 2006 10:00 AM
