2012 MDX CMBS/ACC warning light on
Old Feb 27, 2018 | 11:28 AM
shurik74's Avatar
Hey AZ fellas...
Our 2012 MDX have this warning came up and don't go away, I've tried to search forum for a fix but having some problems using multiple words search. So far no luck to find anything useful. I would greatly appreciate if someone knows a fix to share here. There is nothing that blocking radar at front or dirty, this is a CA car that has no rust even, 99% problem somewhere else.
Thank you in advance...
Old Feb 27, 2018 | 12:22 PM
mrgold35's Avatar
mrgold35
The only time I got the CMBS/ACC warning was when snow/slush from the hwy froze up the entire front bumpers covering the little radar plastic cover. I had to pull off an exit to clean the panel to get the error lights to go away. The CMBS/ACC system seems pretty solid. Might have to take it into Acura to see if you have a bad sensor or loose connection and what error code pops up? You can also turn off the CMBS and ACC to see if the error warning goes away until you take it in.
Old Mar 2, 2018 | 08:39 PM
shurik74's Avatar
Thanks for a suggestion mrgold35. None of them helps to remove this warning
Old Oct 18, 2024 | 01:21 PM
EL_PIC's Avatar
Rich and Famous
Check out your brakes and fluid
Old Nov 10, 2024 | 08:12 PM
djtsmith007's Avatar
ElectroMechanicalEngineer
Originally Posted by shurik74
Hey AZ fellas...
Check here? https://acurazine.com/forums/1-2g-md...2013-a-970625/
Ronzin
1/2G MDX (2001-2013)
Jan 22, 2026 08:16 AM
Exterminator
Jul 16, 2024 12:48 PM
1MDXer
3G MDX (2014-2020)
Mar 15, 2024 02:37 PM
Saleem Merchant
3G MDX (2014-2020)
Nov 1, 2023 06:45 PM
SilverTLType-S
3G MDX (2014-2020)
Aug 29, 2022 07:11 AM
