2016 MDX all lights on
Old Jul 29, 2021 | 04:34 PM
SilverTLType-S's Avatar
I am not sure what the heck is going on with my wife's 2016 MDX adv tech SH-AWD. She has all the lights on the dash the car starts when i pulled the code it said p0001- p003 misfire codes and the VSC brakes lane mitigation every error code know to man. I looked at the battery its ok reading normal check the 20 amp bus fuses no issues. I called Acura said could be bad gas or a sensor anyone had this happen to their vehicle.
Old Jul 29, 2021 | 05:19 PM
just to verify; how old is the battery?
2nd; I would pull the negative terminal from the battery to reset the codes...if the codes come back, then you know you have an issue for real.
Old Jul 29, 2021 | 05:21 PM
I have changed the batteryast may so it should be good so I have a real issue I guess
Old Jul 29, 2021 | 05:40 PM
did you pull the negative cable to reset the code?
Old Jul 29, 2021 | 05:41 PM
is it a misfire code or is it the fuel pressure regulator code that you noted in your first post?
because when I google the p0001 noted in your first post, fuel pressure regulator comes up...not a misfire code.
Old Jul 30, 2021 | 10:41 AM
Reset the battery all last night vehicle drives no check engine just all lights are on will take to a shope next week idk whats wrong with it
Old Jul 30, 2021 | 10:51 AM
that's likely a good bet, taking it to a shop.
i was willing to help tho, if you still want to troubleshoot
Old Jul 30, 2021 | 01:47 PM
I have tried everything I have seen on the lights and to no avail even tried checking fuses think its something else or a sensor that is causing this
Old Jul 30, 2021 | 04:25 PM
Edward'TLS's Avatar
6G TLX-S
Sounds like a electrical grounding point may have come loose.
Old Jul 30, 2021 | 05:19 PM
Possibly will look sunday thanks
Old Aug 29, 2022 | 07:11 AM
PeterPort's Avatar
This happened on my wife's 2015 MDX. Turned out to be a dirty Mass Air Flow sensor caused by leaves getting past the air filter.
dbhansali
3G MDX (2014-2020)
Apr 26, 2023 07:48 AM
Shyamal Shah
3G MDX (2014-2020)
Jan 23, 2020 06:49 PM
deeebo
1/2G MDX (2001-2013)
Mar 12, 2017 04:10 PM
hyojiggy
Apr 29, 2010 12:34 AM
