2011 MDX DRL lightbulb replacement
Old Jun 14, 2011 | 09:47 PM
nctuan03's Avatar
Hi everyone, I'd to know if anyone in here has replaced DRL lightbulb for LED on their mdx. If so, is it just plug and go or you have drl error on the dash . Is it easy to replace or you have to take the bottom panel of the front bumper to have access to the light? Any tip would be helpful, thanks guys
Tuan
Old Jun 18, 2011 | 08:49 PM
bobin's Avatar
bobin
Yes i have just replaced my DRL lights with brighter bulbs Piaa Extreme White.
You have to remove the frount bumper to do this or be very skilled and remove the bottom front cover. Note you can not put in Xenon kit in the high beam or DRL, as they are on the same circut as told by dealer.Will flicker or get a code in the dash. I have exnon in the fog lights and brighter bulbs in the lows. it was a lot of work for the first time next time much easyer.
Old Jun 21, 2011 | 12:54 PM
aiia's Avatar
Tuan,
Your manual also has the instruction of how to remove and install the DRL or Fog light. I did mine DRL with LED and that needed the decoder, and I have that done successfully. the LED foglight didn't need the decoder. Mine also 2011.
Old Jun 23, 2011 | 05:24 PM
nctuan03's Avatar
Aiia, bobin... thank you so much for replying. Hey aiia.. did you purchase led drl with resistor and led fog by itself from v-led ? Does LED fog fit the housing? or it is too long? Thanks
Tuan
Old Jun 24, 2011 | 12:17 PM
aiia's Avatar
I bought everything on Ebay. The LED fog fit without any issues and doesn't need any resistor. The DRL though needed. I didn't use v-led. I heard you don't need resistor for it, but it's more expensive.
Old Jun 26, 2011 | 05:43 PM
myroncuz's Avatar
6th Gear
i just changed out my hi, fog, and drl to hids on my 08. im waiting on my d2s for my lo beams. let me know if you want some leds for your leds or even an hid kit.
Old Aug 18, 2011 | 02:14 PM
romanone's Avatar
9th Gear
Low/Hi and Fog - 5000K HID
Just swapped my Hi beams, Low beams and Fog lights to 5000K HID's
Low beam I used Phillips D2S bulbs - $90 a bulb. Looks better then stock.
mada51589
Jan 9, 2025 04:40 PM
Mr.Tea
1/2G MDX (2001-2013)
26
Oct 9, 2015 04:27 PM
spiel08
Sep 7, 2015 08:19 PM
Snafunk
Sep 3, 2015 08:01 PM
Fadij
Sep 2, 2015 08:31 PM
