2005 MDX Timing belt stuff
Old 01-01-2011, 04:58 PM
Jchick's Avatar
Question 2005 MDX Timing belt stuff
Does anyone have the pages from the service manual for doing the timing belt change? I'm considering buying an electronic manual off of eBay, not sure what kind of quality I'd end up with.
I'm at 103K and considering doing it myself over a weekend. Probably buy the AISIN TKH002 kit from rockauto. I've seen various posts and even a couple of youtube videos that seem helpful, makes me think it's do-able in my garage with not many tools.
Old 01-02-2011, 12:09 AM
Its good to be FRESH!!
philly fresh's Avatar
https://acurazine.com/forums/showthr...ng+timing+belt
step by step with photos
Old 01-02-2011, 12:10 AM
rock auto has great prices and really easy to purchase since it comes in a kit already for you. good luck.
Old 01-05-2011, 04:02 PM
The Box
vas25tl's Avatar
I just don't know if I'd ever attempt to do this on my own. Keep us posted and good luck!
Old 01-16-2011, 04:52 PM
deejayphilo's Avatar
You needed a serious high torque impact wrench. Like the 975ft/lbs from harbor freight only cost $85. Then bring it back when your done.
Old 01-16-2011, 05:16 PM
Jchick's Avatar
Or that crankcase pulley removal tool from Amazon for $25. I think I'll just get that and not worry about air tools.
Old 01-23-2011, 09:09 AM
littlej72's Avatar
Crank bolt will be very tight, especially in the salt belt. Even at the dealer often an impact will not crack it loose, you need a strong gun with a large volume of available air at fairly high preasure. We usually just use a crank tool and a huge bar. Other than that the timing marks on the 03+ mdx's is a bit hard to see, just make sure to set tdc, nothing moves while you work and double check it all. Kind of a messy job with the water pump for a home project but just bring your mop/hose as its hard to catch all the coolant in a pan. PCM also has to come out for this job to be done right, make sure the key is out for a while before removing the cam lock connectors as well as making sure the connectors are properly clicked in prior to sliding the cam lock over to resecure otherwise you will break it and have a ton of trouble.
Old 01-23-2011, 04:28 PM
Jchick's Avatar
Good advice. I'm going to tackle it in a couple of weeks. Should be just over 105K then. Thanks
Old 06-02-2013, 01:57 AM
spydercatt's Avatar
Here is a detailed video with step-by-step instruction onthe replacement of the timing belt on the Honda Acura V6 J Series engine,including the replacement of the pulleys, tensioner, as well as the water pumpand special tools needed to complete the job.
vaughanml2
11-01-2021 10:16 AM
redsox68
09-16-2015 06:18 PM
merc009
09-14-2015 06:43 PM
asahrts
09-04-2015 05:55 PM
Quick Reply: 2005 MDX Timing belt stuff
