2004 MDX Check Engine Lite ON
Old 04-02-2010, 01:24 AM
3rd Gear
acura92870's Avatar
Hello Guys;
2004 MDX. with 133123 miles
MIL on with;
DTC P0171: Rear Bank (Bank 1) Fuel System Too Lean
DTC P0174: Front Bank (Bank 2) Fuel System Too Lean
Replace Both front & rear air fuel sensor and clean pcv valve.
MIL still on; after 4-5 days.
Any Help? Thanks
Old 04-02-2010, 01:39 AM
akord 97's Avatar
Do you have a K&N air filter? Those codes refer to the MAF sensor. Its either dirty or malfunctioning. Or possibly a vaccuum leak downstream of MAF. There was no need to replace the A/F sensors, all they did was detect the lean condition because of bad MAF reading.
Old 04-02-2010, 08:03 AM
RACINGHART03's Avatar
Could be injectors. You need to look at fuel trims on an OD2 scanner.
Old 04-04-2010, 07:36 PM
kotomoto's Avatar
u said MIL STILL on do u mean u didn't reset it ??
if not it takes 40 key cycle to turn it off IF the problem is fixed disconnect the battery
MikeYutkin
09-10-2015 10:13 PM
Bahamanurse1
09-10-2015 10:05 PM
HeloDown
09-08-2015 06:51 PM
bryan zaragoza
09-08-2015 12:28 AM
whitesoxsfan12
09-07-2015 04:07 PM
Quick Reply: 2004 MDX Check Engine Lite ON
