2003 MDX Cluster Swap no Fuel Gauge
Subscribe
Nov 11, 2018 | 09:27 PM
Hey everyone ... happy holidays. Odometer lights go out on my old cluster, so I swapped it with a junkyard one ... everything works, except the fuel gauge, it's stuck on E with the yellow empty light on. This is the second junkyard cluster that I've swapped; I returned the first one because of the same issue, fuel gauge stuck on empty, yellow empty light on.
When I reinstall the original cluster, everything works, except the aforementioned odometer lights. At first, they are very faint, eventually, they completely black out... annoying... a new module is $300 + soldering and swapping ... a junkyard cluster is a $100 throw, easy decision.
Questions:
1. Is there a reset procedure for this?
Note: My MDX has separate Reset and Select buttons, not just one Sel/Reset button. I already tried the procedure with the lights on, key in #1 position, turn lights off and on etc. ... no dice ...
2. Is it as easy as swapping or jumping a couple of wires in a harness?
3. Can I swap or modify the fuel gauge from either cluster?
4. Does a wrecked MDX (with airbag deployment) from this era automatically reset / short out fuel gauge related wiring / print board continuity?
5. Will disconnecting the battery or fuel sending unit and reconnecting them reset anything?
Thanks in advance for advice ...
Reply 0
Nov 12, 2018 | 01:57 AM
Are you swapping for same year dashboard?? because otherwise the Fuel Gauge electric diagram is very simple... If you are swapping for a different year it could have that specific wire moved into another pin in the plug which could lead to a no-signal fault.
Reply 0
Nov 12, 2018 | 11:18 AM
Thanks, I will call the salvage yard and get the specific year of the donor vehicle. Could the problem be solved by getting a wiring diagram and swapping two pins?
Reply 0
Nov 12, 2018 | 04:00 PM
I really believe so.. Cant say for sure I haven´t work on many 1Gs.
Reply 0
Nov 13, 2018 | 10:06 PM
Skirmich, where can I find the pin out diagram for the instrument cluster harness on a 2003 MDX? thanks
Reply 0
Nov 13, 2018 | 11:30 PM
I found the harness diagrams on All Data, but the fuel gauge isn't specifically identified, just "gauges and indicators" pin 2, connector A for an '03 model with Nav ... I'll get the year of the donor cluster from the junk yard, and hopefully swap no more than 2 wires ... any more advice?
Reply 0
Subscribe
