2003 CL-S Rims on 2005 MDX
Old 11-27-2008, 08:40 PM
gurot1's Avatar
I have a set of 2003 CL-S rims that I was thinking of using on the MDX for snow tires. Would the offset be okay? Are they sturdy enough? I would have to buy the tire pressure sensors
Old 11-28-2008, 12:12 PM
Moderator Alumnus
FiftyFive's Avatar
They should be ok.
Old 12-03-2008, 01:36 AM
Type34's Avatar
The stock 2005 MDX wheel is 17" x 6.5" with a 45mm offset. The 2003 CL Type-S wheel is 17" x 7" with a 55mm offset (both have the same 5 x 114.3mm bolt pattern). So I'm not certain there's enough brake clearance with 10mm closer wheels (the MDX's AWD may be an issue as well).
Also, you may need hub-rings unless the CL-S wheel matches the 64.15mm hub of the 01-06 MDX. Most Honda/Acura wheels have the 64.15mm hub, but if not, the wheels will vibrate (without hub rings). I'm also not certain if the 2003 CL-S wheel's stem opening can take TPMS.
Have you thought about a used set of 18" RDX wheels? (they definitely fit + can take TPMS). You can get them relatively cheap on eBay...food for thought...
Old 12-04-2008, 11:38 PM
gurot1's Avatar
I wasn't sure how the offset and the all wheel drive system would affect things. In terms of 18" RDX, I would rather stick with 17" for snow tires, I was even thinking of downsizing to 16", but I'm not sure if I could get steelies that would clear the brakes or not. I'm not sure about TPMS either. Do the Honda Ridgeline 17" have TPMS? I've seen some guys use the Honda rims on their MDXs.
On the CL-S I got lucky with the combo of the offset of my OZ superleggeras and CT drop not having any rubbing issues with wider than stock tires! I think the 03 cl-s rims should match the hub of the MDX.
Old 12-05-2008, 12:19 AM
Type34's Avatar
Honda Ridgelines are 5 x 120mm (same as the Odyssey), which will fit the 2007+ MDX but not the 2001-2006 models (5 x 114.3).
If you're looking for a Honda OEM wheel, most of the 17" 5 x 114.3 Honda Accord wheels are 55mm offset, but the 5 x 114.3 Civic wheels are 45mm offset - this includes the 16" EX wheel (5-spoke) and the 17" Si wheel as well...both of which can take your TPMS. And also the Acura 16" and 17" RSX wheels will fit as well (5 x 114.3 with 45mm offset).
Here's an example of 4 xlnt condition 16" RSX wheels for $380 including shipping - not bad
Old 12-09-2008, 09:55 PM
gurot1's Avatar
Thanks for all the info on the Honda/Acura OEM rims and the link. That looks like a good area to check out. Does anyone know if steelies fit the MDX?
Old 11-27-2009, 11:18 PM
gurot1's Avatar
I know it's been a while...but I thought I should update. The OEM CL-s rims work fine. I mounted snow tires on them and there have been no rubbing/vibration issues; they fit on fine. In fact it got rid of the shuddering in the steering wheel I had been feeling with the all-seasons... they probably needed to be balanced.
Old 11-28-2009, 01:54 PM
Moderator Alumnus
FiftyFive's Avatar
Good to hear!
Old 11-28-2009, 08:55 PM
THƎSƎ HOPƎFUL MACHINƎS
jsilas's Avatar
^ Glad it worked out for you! Any photos of the CL-S wheels on the MDX? I'm trying to picture it in my head, but would love to see a picture or two.
Old 11-29-2009, 08:17 PM
The Box
vas25tl's Avatar
I have to do it
Old 11-30-2009, 09:12 PM
gurot1's Avatar
I will take some pics this week. Hopefully I can remember my logon and password for site I used for image hosting (been a few years since I last posted any pics up lol) The rims make the truck look a little sportier, but they don't stick out at you.
Old 12-06-2009, 09:28 AM
Nuckz23's Avatar
Yeah get some pics up. I have some TL-S wheels sitting around that I might throw up on the MDX.
Old 12-13-2009, 07:29 PM
kzak's Avatar
any update on these pictures? i like this idea.
Old 12-17-2009, 01:09 AM
akord 97's Avatar
Someone put TL rims on a MDX.
Old 01-15-2010, 12:27 PM
Majofo's Avatar
Received 11,841 Likes on 8,573 Posts
fk those tl rims don't look too bad.. lol..
btw.. if the offset is 10mm out on the CL-S but 0.25" wider from the center then it should almost be the same, definitely enough clearance room. Agreed, post up some pics.
Old 02-11-2011, 02:50 PM
7th Gear
sq_creations's Avatar
I like the Tl Rims on the mdx!
Old 02-12-2011, 08:55 PM
BlacknWhite23's Avatar
I just put some '11 CRV wheels on my '01 MDX. Looks pretty hot, imo. I also have a set of civic 16" wheels that are in pretty good shape that I would be willing to part with if anyone needs some. $200 buys the civic wheels +shipping.
Link
Lemme know.
Mike
Old 02-21-2011, 09:46 PM
gurot1's Avatar
Just a few years late, but here are pics of the CL-S rims on the MDX.
Powder Monkey
2G CL Problems & Fixes
09-09-2018 12:55 AM
agupta3224
05-23-2017 08:30 AM
Pham Alvan
03-16-2016 09:17 AM
navtool.com
3G MDX (2014-2020)
32
01-20-2016 11:43 AM
tristann616
1/2G MDX (2001-2013)
09-22-2015 11:40 PM
Quick Reply: 2003 CL-S Rims on 2005 MDX
