New Wheel/Tire specs thread with pics
#961
1.Brand of Rim - Varestoen
2.Rim size 18x9.5 F 18x10.5 R
3.Offset - +25 front ( trying to find out rear
4.Brand of tire - Genral
5.Tire size - 245/40/18
6.Drop Type and Amount - tein advanced 1.5 drop
7.Do they rub
8. Transmission type 5AT for a type S with brembo
7.Do they rub
#963
7th Gear
1.Brand of Rim -(Miro) Powder coated stone Bronze
2.Rim size - 18X9.5
3.Offset - +40 square but added 5MM spacer for the rear.
4.Brand of tire -Goodyear f1 asymmetric 2
5.Tire size -245/40-18
6.Drop Type & Height - TEIN BASIC 2'' drop F/B
7.Do they rub - No rubbing
8.Transmission type - 5AT
[IMG]
[/IMG]
2.Rim size - 18X9.5
[IMG]
[/IMG]
#964
Well I'm sure 20mm or 25mm should be fine. And honestly, great pick up for $300. Hopefully one day I will be able to post on here. I am long from it.
#966
#967
I have ASPEC wheels and run 245/40/18 as well. Check my progress thread for how they look with 15mm front and 20mm rear spacers.
#968
#969
1.Brand of Rim- MB Battles
2.Rim size (diameter and width) – 17x9.5 + 15
3.Offset- +15 Square
4.Brand of tire – Yokahama S-Drive
5.Tire size - 215/35/17
6.Drop Type and Amount – Function & Form Type I not sure how much of a drop
7.Do they rub – Not unless it's a hard turn with bumps
8. Transmission type - 6MT No spacers, clears BBK
#970
Abyss Beauty
1.Brand of Rim- Concept One CS-16
2.Rim size (diameter and width) – 19x10
3.Offset- +20; +5 & 0 with spacers.
4.Brand of tire – Achilles ATR
5.Tire size - 225/35/19
6.Drop Type and Amount – BC coils w/ custom rates; A lot
7.Do they rub – Barely
8. Transmission type - 5AT
#971
1.Brand of Rim- Niche Concourse
2.Rim size (diameter and width) - 20x8.5
3.Offset - 38mm
4.Brand of tire - Nankang
5.Tire size - 255/30/20
6.Drop Type and Amount - none
8. Transmission type (use of spacers if 6MT) - 5AT
#972
1. Brand of Rim - Rays Forged (370 z nissian rim)
2. Rim size - front 19x9 / rear 19x10
3. Offset - +47 front +30 rear
4. Brand of tire - pirelli p zero
5. Tire size -245-40-19 fronts - 275/35/19 rears
6. Drop Type & Height - Stock (rear has 2 shims each side)
7. Do they rub - rubbing on turns... (70 mph on a bend) and 2 people in rear on a dip
8. Transmission type - auto
TripleLex (04-13-2016)
#974
Do you have cambers from front to back or just the back
#976
1.Brand of Rim - TSW Interlagos
2.Rim size - 18X9.5
3.Offset - +40
5.Tire size -265/35/18
6.Drop Type & Height - TEIN Street Flex 13" Hub to Fender Gap
7.Do they rub - No rubbing, Slight roll on rear
8.Transmission type - 6MT, no spacers needed, tons of room for Brembos
2.Rim size - 18X9.5
3.Offset - +40
#977
1.Brand of Rim - Avant Garde M580
2.Rim size - 19X8.5
3.Offset - +35
4.Brand of tire -Bridgestone SO4
5.Tire size -245/35/19
6.Drop Type & Height - TEIN Street basis 25" ground to fender
7.Do they rub - only in reverse on inner plastic fender when full lock
8.Transmission type - 5AT, Type S, close fit to brakes
2.Rim size - 19X8.5
3.Offset - +35
#978
1.Brand of Rim - FK Ethos
2.Rim size - 20X8.5
3.Offset - +35 (all around)
4.Brand of tire - falken azenis pt-722
5.Tire size -235/30/20
6.Drop Type & Height - Stock with A-Spec kit
7.Do they rub - Not one bit
8.Transmission type - 5AT, Base
2.Rim size - 20X8.5
#979
1 rim brand xxr531
2 rim size 19×8.5 19×10
3 offset +35 all round
4 tire brand ohtsu fp8000
5 tire size 235 35 19 255 35 19
6 drop tein street advanced still could go lower
7 do they rub rolled all fenders still rub inner front fender liner just sometimes
8 trans 5at
8 trans 5at
#980
Need new pics
#981
Needs a 930
Will a 245x40x19 on a 19x8.5? I know a 235x40x19 will fit for sure but the price on those are like 225-300 from what im looking at vs the 245's are "regularly" priced, basically all under 200 per
Undying Dreams (09-05-2015)
#984
#986
1.Brand of wheel - Miro 112
2.Wheel size (diameter and width) - 18 x 9.5
3.Offset - +40
4.Brand of tire - Conti DW
5.Tire size - 255/40
6.Drop Type and Amount - None yet
7.Do they rub - Not that I have found
8. Transmission type - AT
Better pix later.
Elemental. by VisualEchos, on Flickr
Elemental II Desktop by VisualEchos, on Flickr
3.Offset - +40
Better pix later.
#988
1.Brand of wheel - Stock Type-S
2.Wheel size (diameter and width) - 17X 8
3.Offset - +30
4.Brand of tire - continental
5.Tire size - ?
6.Drop Type and Amount - H&R Race Springs & TruHart Struts (2 in)
7.Do they rub - NO
3.Offset - +30
5.Tire size - ?
7.Do they rub - NO
Ceaze (05-14-2017)
m00nix (02-02-2021)
#991
Sorry guys... Here is the correct format
Brand of wheel - Advanti HY Hybris
2.Wheel size (diameter and width) - 18x8
3.Offset - +35
4.Brand of tire - Capitol
5.Tire size - 235/40/18
6.Drop Type and Amount - Tanabe DF-210 koni yellow
7.Do they rub - NO
8. Transmission type - 6MT, clears Brembos
3.Offset - +35
7.Do they rub - NO
#993
Brand of wheel - AME Spec-R two piece
2.Wheel size (diameter and width) - 18x9.5F 18x10R
3.Offset - +45 fronts, +42 rear
4.Brand of tire - GT-Radials
6.Drop Type and Amount - Tein S-Tech, about 1.5 all around
7.Do they rub - NO
8. Transmission type - Base Auto
camber set at 1.0 all around, no fender mods, no rubbing even with a fully loaded car. Wheels are flush with the fenders without being "stanced", perfect for my daily driver.
7.Do they rub - NO
#994
Finally got my BC Racing coilovers on, so I thought I'd update mine. I initially chose the 255/40 (which is a ½" too tall) over the 255/35 because I was going to leave the car at stock height. The tires seemed a bit tall a that time, because of the wheel gap. Once the gap was gone the tires set just perfect.
3.Offset - +40
6.Drop Type and Amount - still settling, I'll let you know
7.Do they rub - No
3.Offset - +40
7.Do they rub - No
#996
3.Offset - +30
5.Tire size - ?
7.Do they rub - NO
3.Offset - +30
5.Tire size - ?
7.Do they rub - NO
#997
1.Brand of wheel - XXR 530
2.Wheel size (diameter and width) - 18x8.75
3.Offset - +20
4.Brand of tire - Nankang NS-20
5.Tire size - 225/40/18
6.Drop Type and Amount - Tein SA Coilovers, not sure on drop.
7.Do they rub - NO (rolled rear fenders)
3.Offset - +20
#998
BeezleTL85 (02-13-2016)
#1000
Spinnin them beats
1. Brand of Rim - Avant Garde M510
2. Rim size - 19x8.5 front, 19x9.5 rear
3. Offset - +35, +40
4. Brand of tire - Continental DWS
5.Tire size - 245x35x19 all around, minor stretch on back
6. Drop Type and Amount - Tein H spring, .8-1.0 inch drop
7. Do they rub - Nope
