Window Tint Advice
Window Tint Advice
I want any advice about Window Tint anyone has. I'm looking to tint my windows on my 06 TL for the first time. Like what tint looks best, brand, percentage, how much I should be paying etc.. Thanks
Hi Warren,
You're new. I've seen a couple new threads you've opened in the last few days. Don't feel the need to open a new thread for everything. Please utilize the search function and even use google (type in Acurazine first) and then whatever your heart desires. I promise you Acurazine is a GOLDMINE of information and with a little due diligence, you will find everything you need.
It's the whole, "teach a man to fish" mentality; it's not that we don't want to help, it's that the information is out there already
ggesq (01-22-2015)
I like 35% tint all around (except windshield). My tinter charges me $200 to do a sedan with a quality Llumar film. He also makes sure tint goes all the way behind the rubber strip on the back quarter windows (search and you'll see what im talking about), and he tints the entire rear window and does not cutout around the third brake light which looks tacky IMO.
Also, be advised that 3G window swipes will eventually scratch your tint with vertical lines. Some cars do it worse than others, but either way im pretty sure every TL will do this even if its minor. To fix this I used a felt strip wrapped around the inner window swipe. The door panels need to be removed to do this, but its not hard. You then pull the rubber strip off the metal door, and wrap it entirely with felt then jam it back on the metal door so it stays. No glue or anything required and has been working perfect for me for I think 3 years now.
Hope this helps.
Hope this helps.
Registered Bunny
Hope this helps.
Hope this helps.
When I went to install my tint, the guys knew this car had an issue with scratching so offered me to install "moleskin felt" for 10 bucks a window. *shrug* I figured I'd let them do it for a little less headache.
I got tint done about 6 years ago but lately have issues with the adhesive getting on the windows now. JTS97Z28 was it pretty easy to get felt back on there and staying with no adhesive? Can I justvuse regular felt from a fabric store or a certain kind?
I might just redo it myself and use goo gone to get the old adhesive off the metal area. Door panel is no issue I've taken it off before for sound deadening
For the OP, I've tinted many times using 3M and solar gard. I like solar Gard more but both are great. Just dont go super cheap and make sure to get a brand with a lifetime warranty.
Oh yeah it was so easy that im not even sure why guys mess around with this moleskin stuff with adhesive that eventually gets all over the windows. I used felt material that I got from the fabric store and its been perfect for about 3 years now. When you pull the rubber strip out you just cut a strip to length and enough to wrap completely around the entire strip. Its then held back in place on its own when its pushed back on the metal door panel, then the door panel itself. I just made sure that the felt was pretty tight around the stripe before placing it back on the door and thats all there is too it. They have been flawless since I installed them. years ago and not a single trace of a scratch on any window.
I got 35% once in my life and regretted every moment. Since then I only get 18-20% all around.
I also tried 5% but it makes the window look like plastic. At least 18-20% gives it a nice dark window effect and it keeps the heat and eyes out.
Registered Bunny
Depends where you are. In winter in the boonies it can get a bit dark but in the city it's usually fine. I suggest not going too dark on the back glass, personally I dislike it if I can't see properly while backing up.
I must be lucky because I have one faint scratch line on each rear window thats barely visible and thats it, nothing on the front. Has been tinted for over 2 years.
soupi
14
11-15-2015 11:15 AM
