KP Technologies Window roll up module install 3G Garage #I-097
Old 05-31-2007, 10:41 PM
  #281
OMGWTF4THGENTL
Kennedy's Avatar
Originally Posted by tonyph33r
it seen like mine was stuck something once i lock and i hit the lock button 2 time the windows roll up a litter bit then when i try to unlock it wont unlock
Let me ask again:
You using those "quick connects aka scotchlocks" to make the connections?
Old 05-31-2007, 10:43 PM
  #282
tonyph33r's Avatar
yea the clip that i buy from auto part. it work couple hour later it wont work anymore
Old 05-31-2007, 10:55 PM
  #283
OMGWTF4THGENTL
Kennedy's Avatar
TAKE THE CLIPS OUT. STRIP THE WIRE AND WRAP THE WIRES TOGETHER.
Almost every issue expereinced here was due to those damn clips. DON'T USE THEM.
Report back when that's done.
Old 06-01-2007, 02:09 AM
  #284
datmrman's Avatar
Originally Posted by Kennedy
Mine went in and worked the first time, and is still working great a year later.
I don't know Kennedy, mine has been fine as well and I used the clips.
JD TL-S, everything is good to go. The instructions work and the vendor is a sponsor here.
Old 06-01-2007, 04:56 AM
  #285
kpierson's Avatar
Our site is NOT a secure site, but we don't accept payments through it, so that shouldn't be an issue (payments are handled via Paypal or check).
If the windows are raising slightly I would still remove the yellow wire, that is a sign of it not being hooked up correctly.
Are you only pushing the 'LOCK' button twice? You need to press it, wait about 1 second, and then press it again. If you press it twice quickly it will NOT work.
Old 06-01-2007, 05:00 AM
  #286
kpierson's Avatar
On the timing side you must:
1. Press and release 'LOCK' button
2. Wait between 0.8 - ~1.5 seconds
3. Press and release 'LOCK' button a second time.
4. Wait.
Do NOT hold the 'LOCK' button down. You must press and release it each time.
Old 06-01-2007, 05:09 AM
  #287
JD TL-S's Avatar
OK, I guess when paying with Paypall thats the secure site. Do you have a phone # so I can order on the phone. I am having comp problems right now and want to order ASAP. This sounds so cool.
I will definetly solder everything I am anal about any quick fix I don't have any equipement to check the wires b4 doing install. So I will just cut, splice, twist, solder, tape, and check to se if it works b4 putting door back together.
So when I order, just tell them about this site to get a discount? How long to get to Northern IL. Thankyou for your help Jeff D.
Old 06-01-2007, 07:17 AM
  #288
Retired!!! ON TOP!!!
rodneyc77's Avatar
Hey Kpierson...
I just wanted to thank you for such a great product... I've had it installed for over a year now and it's still functioning great... Also, thank you for such a quick response to my issue the other day... you were right... I just had to do a hard restart to the unit...
Old 06-01-2007, 08:00 AM
  #289
kpierson's Avatar
You can place an order through Email, but we don't have an ordering phone number (Orders at KPtechnologies dot com).
We are not currently offering any promotions on any of our products. We can run another group buy if there is enough interest (20 or people).
Thank you,
Old 06-01-2007, 12:30 PM
  #290
OMGWTF4THGENTL
Kennedy's Avatar
Trust me when I tel you this... Thos eclips are more trouble than they're worth. I've ruined a few electrical compnents on my VW with them.
The lead to intermittent connections because:
1) The metal "bite" backs out
2) they're aluminum, aluminum to metal exposed to the elements will corrode.
3) they make 1 square mm of contact, vs. a solid 2-3 square cm with a copper to copper with solder connection.
ALWAYS... coper to copper with solder. That way, when it comes to trouble shooting you'll never have to question "the connections".
Old 06-01-2007, 01:39 PM
  #291
kpierson's Avatar
If you use the correct size for the wire splice they can be somewhat reliable. The problem is that most people can't size them correctly, and that leads to problems.
Another issue, espeically with KPtech products, is that our wires are typically bigger then the OEM wire, espeically with the key cylinder output. All of our wires are 20ga, and most key cylinder wires are 22ga. The scotchlocks are designed to work with two wires the same size, as they have the V cut in to them that is supposed to center on the wire. If the wire isn't big enough, it won't center.
Also, cars introduce two factors that can't be ignored - vibration and moisture. Both of these will severely limit the life span of a scotchlock.
Old 06-01-2007, 01:48 PM
  #292
A SiQ TL's Avatar
4. Wait.
I had timing issues at first too. This is what helped me out.
With your thumb on your remotes LOCK button, think like you have the key in the drivers door lock and are rolling the windows up that way. I will actually turn my hand twice(the one holding the remote) just like I would be doing if I had my key in the lock. With each turn, hit the LOCK button.
Of course it helps if you have actually rolled up the windows with the key a few times to know the rhythm.
Old 06-01-2007, 09:42 PM
  #293
Unofficial Goat
The Dougler's Avatar
I installed mine a year ago with the quickclips and it works greeat. the trick is to ensure a good connection with them, use the heatshrink wraps over the quickconnects so that they cannot move. Or even electrical tape it up very tight and you'll be fine, i'm going to install it in my brothers sometime this week and thats my plan.
Old 06-02-2007, 01:46 PM
  #294
vandido626's Avatar
Mine just stopped working a few months ago...It was pretty cool when it worked.
Old 06-02-2007, 04:35 PM
  #295
OMGWTF4THGENTL
Kennedy's Avatar
Check the clip... I'm telling ya.
Just because 1-2 folks chime in saying "thier clips are working great"... doesn't mean they're great.
Remove the clips and it'll probably work again.
Old 06-03-2007, 08:06 AM
  #296
kpierson's Avatar
Try doing a 'hard' reset by unplugging it for ~30 seconds then plugging it back in. If that doesn't work, send it back to us for a free warranty repair.
Old 06-03-2007, 12:06 PM
  #297
NocturnalTypeS's Avatar
Hey where can i purchase this from i looked at the group buy page on page 1 and it doesmt work??
Old 06-03-2007, 12:39 PM
  #298
kpierson's Avatar
www.KPtechnologies.com
Old 06-03-2007, 02:21 PM
  #299
ililillilillilil's Avatar
Thank you,
i missed out on the GB by a day and I still want one.
just waiting for the next group buy....
Old 06-03-2007, 03:25 PM
  #300
05TLRIDER's Avatar
I don't know where I've been, but for some reason I haven't seen this thread before. Maybe I should start browsing around more. This sounds like a good mod and simple too. I might have to invest in this in the near future.
One question though, I was going through some of the posts and noticed the talk about doing a hard reset on the device. Is this something that should be done every so often? I would prefer to minimize the number of times I remove my door panels.
Old 06-03-2007, 03:59 PM
  #301
kpierson's Avatar
We always recomend doing the hard reset before sending the module back for a warranty repair. By design the module should never have to be hard reset, but we still recomend it before shipping it out.
Old 06-03-2007, 09:25 PM
  #302
JD TL-S's Avatar
I think you only save about $11 during a group buy. Not a big deal.
Old 06-05-2007, 12:35 PM
  #303
kpierson's Avatar
Did you get yours working correctly?
Old 06-05-2007, 01:20 PM
  #304
tonyph33r's Avatar
kpierson: i have e-mail them and that i want a new KB replay but never reply back. Im 100% that i did all the wire correctly.
Old 06-05-2007, 01:31 PM
  #305
kpierson's Avatar
I recieved your Email, but ignored it because of the Email domain name (warezzhq.com) and because we don't have any products that are referred to as "KB". I assumed that that was actually a spam Email, my appologies.
A few quick questions - are you holding down the 'lock' button? You MUST release the lock button each time you push it, do NOT hold it down.
Are you pushing the 'lock' button ONLY twice? The correct sequence is:
1. Push and release "LOCK" button
2. Wait approximately 1 second
3. Push and release "LOCK" button
4. Wait approximately 3-4 seconds before windows start moving.
Old 06-05-2007, 02:27 PM
  #306
tonyph33r's Avatar
i just test it and it work now i try agian it wont work
Old 06-05-2007, 02:31 PM
  #307
tonyph33r's Avatar
when i push lock and wait for 1 second then i push lock agian it rolll up a litter bit. then i try to unlock the door it wont unlock. i have to put the key in the hole to open the door
Old 06-05-2007, 02:36 PM
  #308
tonyph33r's Avatar
when u push lock and wait 1 second then push lock agian do u hear a sound?
Old 06-05-2007, 02:46 PM
  #309
OMGWTF4THGENTL
Kennedy's Avatar
Again it's either:
1) a shaky connection
2) bad timing
if you hear the alarm chirp, you probably have timing right... please check your connections and make copper to copper connections.
Old 06-05-2007, 02:50 PM
  #310
tonyph33r's Avatar
sorry kennedy im kind new to this but can u explain what is bad timing?
Old 06-05-2007, 03:00 PM
  #311
OMGWTF4THGENTL
Kennedy's Avatar
Old 06-05-2007, 03:10 PM
  #312
kpierson's Avatar
From memory, I don't believe a sound is made. I don't have a TL so it's hard for me to say.
I will shoot you an Email later today about returning the module for a warranty inspection. It doesn't sound like the module is faulty (typically, when they are bad they don't work at all). Intermittent issues are almost always caused by people not pushing the buttons correctly, people not waiting long enough, or a bad connection.
Old 06-05-2007, 03:23 PM
  #313
tonyph33r's Avatar
that what i did and it roll up a litter bit then it stop.
Old 06-09-2007, 09:46 PM
  #314
Desert_TL's Avatar
Just installed my module. Worked perfectly on the first try. I used wire nuts and electrical tape as opposed to those crimp things. I don't like those... I think they'd be pretty flakey.
I used double sided 3M tape and stuck the module to the inside of the outer metal door panel. I decided not to stick it onto the top of the styrofoam block. That way it would remain relatively hidden for the most part.
BTW, KP, I was able to resolve the shipping problem (clearly).
Old 06-09-2007, 11:43 PM
  #315
'04 6mt Pearl
triggle's Avatar
What are you guys using to re-seal the doors plastic vapor barrier ?
Old 06-10-2007, 09:45 AM
  #316
kpierson's Avatar
Excellent, enjoy!
Old 06-10-2007, 12:48 PM
  #317
Desert_TL's Avatar
It isn't really "sealed" to start with. When you install the module, you just have to rip the plastic slightly in the hole that is already there. Not a huge deal to me, anyway.
Old 07-15-2007, 06:17 PM
  #318
jscout's Avatar
Group buy, group buy, group buy! Set one up and I will buy. Just picked up an 07 TL w/ nav in CGP a couple of weeks ago. Love it!
Old 08-11-2007, 04:12 PM
  #319
3rd Gear
eg6rcr's Avatar
Will the KP Technologies Windows roll up module work with a 2003 Acura CL?
Old 08-11-2007, 05:00 PM
  #320
kpierson's Avatar
I'm not sure about compatibility with the '03 CL.
Can you raise the windows with your key in the drivers door key cylinder?
Quick Reply: KP Technologies Window roll up module install 3G Garage #I-097
