Clogged Brake Line
Clogged Brake Line
Been some questions about sticking brakes, so thought I'd post a recent problem, although not on the TL.
Daughter was on the way home from work in her Maxima, called and complained about the car pulling hard right and a burning smell. Classic sticking brakes. Loaded up tools and headed about 15 minutes from the house. Found right front to be the problem, much hotter than the others. Jacked up the car, tried to push the piston in, no go. Opened the bleeder and got the pads away from the rotor. Drove home using the hand brake.
Once home and in the garage, removed the brake hose and pushed a thin wire through until it stopped at the clog at which point I cut the line in half. As you can see the hose is completely clogged right at the hose brace. Some may split inside and cause a clog, but many just built up corrosion at the brace area:
Not a great picture, but:
Registered Bike Offender
Haha this is a fantastic photo, thanks for sharing. Glad nobody was hurt! Now where are all those people that say you don't need to change brake fluid.
Probably on facebook.
SidhuSaaB
05-30-2020 12:40 AM
lanechanger
10-13-2015 10:56 AM
