Brake Brackets Help.
Old 10-17-2014, 07:40 PM
iiamchili's Avatar
Hi i bought some drilled and slotted Rotors and pads from Ebay they suppose to fit my 05 TL but both front rotors and pad its a little bigger (SMH) rears fit well. The mechanic told me to to buy a bigger size brake Brackets if i want to install those Rotors. What ya think should i do ? or should i buy the bigger size brackets? witch one should i buy ?
Old 10-17-2014, 07:44 PM
Be a better driver
RedRyder's Avatar
Return whatever you bought, and buy quality OE parts from a good brake manufacturer that will be spec'd to fit the same as OEM components.
Old 10-17-2014, 07:47 PM
iiamchili's Avatar
Originally Posted by RedRyder
Return whatever you bought, and buy quality OE parts from a good brake manufacturer that will be spec'd correctly to fit as OEM.
Rotors are quality the are R1 concepts problem is that i already install the rear ones.
Old 10-17-2014, 08:02 PM
paperboy42190's Avatar
Received 1,162 Likes on 847 Posts
you might have gotten the type S/6mt base rotors instead, they are 12.2" compared to the base 11.8"
iiamchili (10-17-2014)
Old 10-17-2014, 08:09 PM
Turbonut's Avatar
Do you have an AT or MT?
Here's the rotor specs:
A/T 11.4" diameter 1.1" thickness
M/T 12.2" diameter .98" thickness
Old 10-17-2014, 08:23 PM
iiamchili's Avatar
AT. so what do have to buy so they could fit ?
Old 10-17-2014, 10:03 PM
Jackass's Avatar
The correct rotors for your car.
Otherwise search for the Brembo swap. You won't like what you find.
1fstTL (10-17-2014)
Old 10-18-2014, 06:23 PM
iiamchili's Avatar
Oh ok thanks
Old 10-18-2014, 07:55 PM
Just a correction, it should be 11.8" rotor for the base AT
Old 10-22-2014, 04:22 PM
Former Sponsor
ExcelerateRep's Avatar
Installing quality components that are proper fitment is vital. Definitely look into our XLR8 brake packages for Acurazine:
https://acurazine.com/forums/sponsor...razine-903264/
Or if you're looking for just front rotors and pads, you can't go wrong with Stoptech rotors and street performance pads. Both are available and in stock on our website.
Brakes - Excelerate - HOA - Japanese Performance Specialist
08_UA7_Gr33k
02-11-2016 02:17 PM
27trains
4G TL Problems & Fixes
09-30-2015 09:44 AM
2ManyHobbies
09-24-2015 09:23 PM
Quick Reply: Brake Brackets Help.
