Outlook 2010
Needs more Lemon Pledge
Outlook 2010
Anyone have Outlook 2010 installed that can help me test something?
I am seeing odd behavior on two machines with Outlook 2010 and was wondering if someone else could do a simple process to see if they can replicate.
1. Open Outlook 2010
2. In the search bar above your inbox messages, type a search you know will result in MORE THAN ONE search hits that are NOT in the inbox directly (should be in subfolders)
3. Click once on the any of the items shown as resulting from the search EXCEPT the very first one so that it shows in the preview pane.
4. Hover your pointer over the various email addresses in the header (To, CC, Your address, etc) for a few seconds and see if the window flickers, goes blank for a second and then puts you into the very first result item in the search result.
I have replicated this on two machines with Outlook 2010 installs and it happens exactly the same... Hweird.
Blame Ashley Madison.
stogie1020 (08-20-2015)
Thanks for trying.
Go Giants
2010 was like 30 years ago.
Outlook 2010
Stogie I can try on 2007 butt that's probably not going to give you the results you were looking for..
Hmmm... Weird.
Well, thanks for trying.
No go here in 2007 either.
I would post a screen video of it, but there really is no way to sanitize it enough to prevent showing things I can't show...
I don't have Outlook 2010 but tried to reproduce this in Outlook 2013 and it was fine. I did have the 2010 before and don't ever recall seeing this happen to me on any PC I used.
On that train of thought... I'm wondering if your .pst is corrupt... have you tried repairing?
It happens on multiple different machines of mine all running 2010.
Are the search results in your Inbox (within subfolders)? Have you tried search results in a archive .pst and do they exhibit the same symptom?
Just throwing out ideas that I would try if I were in your shoes
I don;t have an archive PST, just the active Inbox.
The problem ONLY occurs when i hover over a hyperlinked (blue) email address in the TO or CC field of the preview pane, and ONLY when I am viewing the results of a search..
It's as though there is some issue with the Outlook popup (your mini contact) that appears when you hover over a name in the header of a search result...
Havent tried SM, good question.
Nope, does not happen in SM...
Got any 3rd party add-ins?
OK, another Outlook question...
Someone sends me an email with an address or a company name in it.
I want to be able to highlight the text, right click and choose "search with Google."
Is there a way?
Cut and paste into a google page is so 20th century...
Is there a way?
The web says there is a registry hack, which I tried, and it didn't work...
use this one
Change Default Search Provider in MS Office 2013 Suite - Guiding Tech
I had done it before and had to search for the right page
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Office\15.0\C ommon\General]
"SearchProviderURI"="http://www.google.com/search?q="
"SearchProviderName"="Google"
cut and past that in to a *.reg file and import.
stogie1020 (10-01-2015)
Appreciate the suggestion,. but I had already manually added that to no avail.
Here is what I see when I highlight text in a message and choose "lookup"
stogie, your outlook is all sorts of fucked up
Tell me about it...
If I work on a message long enough for a draft to be auto-saved, I am unable to attach anything to it! I have to start over and get it done in 3 minutes or less!
Meh, minor annoyances. Not worth throwing out the baby with the bath water... Yet.
Company finally rolled out 2013.. (from 2007 )
Added the reg key and it worked perfectly for Search with Google! Thanks for heads up stogmeister and Beelzebubblebutt!
Based on how many licenses I hold and how infrequently I update them, I may simply start using Office 365.
Anyone regret moving to the cloud/app based Office from the standalone desktop version?
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
TLguy42
09-26-2015 11:27 AM
