ROTORA Big Brake Kits: CL, TL, TSX
Old 03-19-2009, 08:50 PM
  #161
slowaccord's Avatar
^^2000 v6 coupe. i bought a 1 piece kit from u a few years back
Old 03-20-2009, 11:02 AM
  #162
Former Sponsor
Excelerate's Avatar
There is no rear kit from ROTORA. We can get you performance discs, pads and lines in the rear but no BBK in the rear.
Old 03-20-2009, 11:08 AM
  #163
Brad
bdeitemeyer's Avatar
Any explanation on why the 99-03 Acura TL (UA5 chassis) or the 01-03 Acura CL (YA4 chassis) rear kits wouldn't work on the 98-02 Honda Accords? I know my front BBK (RBK003.01) is interchangeable with those vehicles, so I'm still confused why the rear setups (RBK101.01/02, RBK140.01/02) wouldn't work. Has someone tested those out before on our Accords?
Old 03-20-2009, 12:34 PM
  #164
Former Sponsor
Excelerate's Avatar
The Accord uses a different rear disc.
Old 03-20-2009, 02:41 PM
  #165
slowaccord's Avatar
i already have rotora oem size rear with hawk pads. i sorta been eye balling the 2 piston rear bbk. just gorgeous
Old 04-01-2009, 03:38 AM
  #166
Feenin on some 20's
ILLustriousUA6's Avatar
06 a/t TL. anod. blue shipped to 95037, and do u have any in stock and how fast can u ship? thanks.
Old 04-03-2009, 03:27 PM
  #167
Former Sponsor
Excelerate's Avatar
ROTORA offers a sky blue metallic. Drilled/slotted rotor or slotted? 1 piece 13" disc or 2 piece?
Old 04-27-2009, 09:11 PM
  #168
Registered TL Lover
RJANACONDA's Avatar
could you just get front and rear calipers or do they have to be paired with the rotors?
Old 04-27-2009, 09:28 PM
  #169
Former Sponsor
Excelerate's Avatar
We can get a caliper kit for the front that works with the OE size rotors but not something for the rear unless you want a BBK.
Old 04-27-2009, 09:53 PM
  #170
nf3d0149ab's Avatar
You can do that?
Just add Rotora calipers...that works?
  #171
Registered TL Lover
RJANACONDA's Avatar
i was not planing on just geting calipers but thinking of maybe mixing and matching there is a large gap between need and want for me.
I need new brakes in the near future
I want low dus/rust/noise
I dont need more stopping power buts its always nice to have
I want them to look pretty
and dont want to have to spend a arm and a leg in the process.
Old 05-01-2009, 09:50 PM
  #172
Registered TL Lover
RJANACONDA's Avatar
would the calipers fit with rotors of these dimencions?
Fronts:
Outer Diameter 300mm
Height 47.2 mm
Norm Thickness 28mm
Hub Reg 64.1mm
Bolt Size 12.6mm
Bolt Circle 5x114.3
Rear:
Outer Diameter 282.5mm
Height 58.6 mm
Norm Thickness 9mm
Hub Reg 64mm
Bolt Size 12.6mm
Bolt Circle 5x114.3
Old 05-05-2009, 11:36 PM
  #173
Former Sponsor
Excelerate's Avatar
Originally Posted by nf3d0149ab
You can do that?
Yes.
http://store.excelerateperformance.c...a/i-92973.aspx
I would recommend ROTORA Slotted rotors and ROTORA H2 ceramic brake pads for you. Also look into stainless steel brake lines and upgrade brake fluid (MOTUL DOT 5.1).
Old 06-24-2009, 06:55 PM
  #174
Former Sponsor
Excelerate's Avatar
All pricing is now on the web store a http://store.excelerateperformance.com Use promo code AZ ROTORA !!!
Old 07-08-2009, 08:04 PM
  #175
bforbrian's Avatar
Josh, how much is it shipped to 14850 for a pair of 2-piece 330x30mm slotted rotors for my rotora BBK? (with the AZ promo code, S&H, everything.)
Old 07-09-2009, 06:15 PM
  #176
Former Sponsor
Excelerate's Avatar
I believe we spoke on the phone. Do you have a 2 pc 13" BBK now? Front BBK?
Old 07-25-2009, 04:00 PM
  #177
Former Sponsor
Excelerate's Avatar
All PM's have been answered. To order use our webstore at http://store.excelerateperformance.com or call us at 203-483-6100. Email us with any questions at sales@excelerateperformance.com
Old 08-17-2009, 12:20 PM
  #178
2003 ABP CL Type-S
eddie30013's Avatar
Is there a deal on the Wilwood front brake kit for the 2003 CL-S?
Old 08-21-2009, 11:11 AM
  #179
Former Sponsor
Excelerate's Avatar
Yes pricing is here:
http://store.excelerateperformance.c...767&Make=ACURA
Old 09-04-2009, 11:53 AM
  #180
2003 ABP CL Type-S
eddie30013's Avatar
What's the difference in performance between the wilwood kit and the rotora kit?
Old 09-05-2009, 01:30 PM
  #181
Former Sponsor
Excelerate's Avatar
Which Wilwood kit and which ROTORA kit? There are multiple kits.
Old 09-10-2009, 11:47 PM
  #182
2003 ABP CL Type-S
eddie30013's Avatar
Wilwood Part #: 126-SL4
and Rotora Part #: RBK003.01
Old 09-11-2009, 06:48 PM
  #183
Former Sponsor
Excelerate's Avatar
The Wilwood kit has a smaller disc and smaller calipers. The ROTORA kit has a better overall finish, but the performance should be similar.
Old 10-21-2013, 02:27 AM
  #184
mistuhandy's Avatar
kinda late but is this still going?
Old 10-21-2013, 04:23 PM
  #185
Former Sponsor
Excelerate's Avatar
We offer STOPTECH BBKs mostly now but PM with your vehicle info and we'll get you a quote.
Old 11-15-2013, 09:13 AM
  #186
OTS mobile audio
simplyclean44's Avatar
I have a 2004 acura tl. auto. rotora bbk front and rear. Rear is 2 piston. front is 4 piston. i need rear brake pads. fc2, and i think it is rp.02.1.155 or something like that. Looking for a universal pad that'll fit. i really don't want to buy a rotora bad unless i have too. any help would be greatly appreciated
Old 03-02-2017, 04:36 AM
  #187
Transmission Pro
Bense's Avatar
Trying to find pads for my RBK003.01
cycdaniel
12-17-2019 10:58 AM
CheeseyPoofs McNut
10-11-2015 11:25 AM
nuldabz
09-03-2015 05:49 PM
Quick Reply: ROTORA Big Brake Kits: CL, TL, TSX
