Where is the main relay or fuel pump relay?
Old 03-29-2012, 08:30 AM
zmwang's Avatar
It's a TL 2000. I've being looking for all over here and the Web, I can't find any picture or hints about the location of the main relay ( or fuel pump relay, are they the same)?
Anyone can help here? A picture with some red circles will be good.
I searched the underneath of dashboard at driver side, and the hood near the driver side. I can't find anything looks like the main relay to me.
Old 03-29-2012, 09:12 AM
Skirmich's Avatar
The Fuel Pump works on the PGM-FI Relay! Uploading a Pic!
Old 03-29-2012, 11:05 AM
zmwang's Avatar
thank you. That black box does not look like those on the Web.
I will check it out tonight again.
Old 03-29-2012, 02:09 PM
victus1's Avatar
Yes, it's the black box. Good luck pulling it out of that metal tab. Pulling the circuit board out of the box was a lot easier for me. While your at it, make sure you re-solder all the connections because they are known to be bad and cause problems. You don't need to suck out the solder already there. I took out the board for that reason.
01tl4tl (03-29-2012)
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
Boraxo
1/2G MDX (2001-2013)
09-29-2015 04:35 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: Where is the main relay or fuel pump relay?
