Where's the brake light fuse?
Old 11-24-2010, 04:44 PM
mnm27mnm's Avatar
Question Where's the brake light fuse?
I looked in the manual and i can't figure out which one is my brake light fuse. All of my tail lights stop working completely and the vsa light and yellow warning light came on. I did research here and i taught it would be the brake light switch but i changed it and my tail lights still don't work.
Old 11-24-2010, 05:16 PM
Opel's Avatar
Under hood fuse box, fuse#13... part of ECM is tied to that fuse as well so if that's burnt out, after replacing, check to see if VSA lights go off on the dash (almost everything ties to ECM through a network)..if not, fuse#17,18 are the VSA modulator fuses, so check those as well.
Goodluck
Old 11-26-2010, 10:57 PM
mnm27mnm's Avatar
Thanks, it was fuse #13, It says "Horn Stop" for that fuse, i don't know what that means but i guess it controls the brake lights, bc i changed it and the brake lights work and the vsa light turned off.
InfamousWRX (07-08-2022)
Old 07-08-2022, 11:56 PM
InfamousWRX's Avatar
I know this is a super old post but it saved my butt today!! VSA light would come on after a few minutes of driving car. That was really the first sign, but didn't sweat it because I thought it was something minor. Randomly went to use horn no dice. Important but still kinda minor. Person on road about a month later told me brake lights were out. Major major issue! I checked. Tail lights worked when I locked and unlocked car… Swapped out brake light switch(twice)… No dice. I looked for the brake light fuse. No dice. Just as I was going to make an appointment for a diagnostic I came across this post. Sure enough the horn fuse was out. After changing that all was well again!!
max366
1G RDX Problems & Fixes
02-10-2014 07:50 PM
billwolf
1G TSX Problems & Fixes
03-25-2012 11:48 PM
droopdog7
1G RL (1996-2004)
10-26-2011 02:15 PM
neocastillo
1G CL Problems & Fixes
05-26-2011 01:22 PM
willz822
05-02-2005 09:56 PM
Quick Reply: Where's the brake light fuse?
