Replacing OEM D2S bulbs
Old 03-28-2010, 11:13 AM
Jays07TLtypeS's Avatar
Hello all-
Has anyone ever replaced their factory D2S bulbs with another manufacturer's? I know Acura uses Stanley bulbs as OEM but I have an '07 TL and wondered if replacing mine with a Philips D2S bulb would provide any upgrade (considering Philips is one of the better bulb makers). Also like halogen's, do HID bulbs ever lose any degree of brightness over time/as they age?
Thanks guys!
Jason
07 TL Type-S w/Nav
Alabaster Silver Metallic
Ebony/Silver leather interior
Old 03-28-2010, 11:29 AM
1fsthatch's Avatar
i think you might have to remove the bumper and myabe even headlights (dont take my word for it)...to get to the bulbs.
Old 03-28-2010, 04:54 PM
yes HID bulbs change color and lose brightness with age,
near the end they usually turn pink or purple on initial startup- then failure comes.
Kaixen is a popular brand with gen2- where many ziners have a lot of hours on 10 year old lights and needed new~
4300k is stock color, many prefer 5000k with more blue and still good white, 6000k too blue but liked by many, and above 6 is not worth trying to see at night with!
ck the sponsored sales threads for a few vendors here
Old 03-28-2010, 06:48 PM
kettlepress's Avatar
I just swiched to the Philips 85...+..whatever bulb on my 04TL and they are crazy bright. I would say easily a third brighter than stock. I got them at http://store.theretrofitsource.com/index.php And I had a local VW specialty shop do the install. They gave me an intial quote of $30 to $60, I told them I hear that it's quite extensive, etc and they are prob quoting me to little. No joke, 2 hours later the guy comes out to the waiting room sweating like a whore in church telling me it's done. They were super cool about the whole thing and just told me to pay $65 and swore that he'd never do another Acura headlight job again.
Old 03-28-2010, 08:24 PM
Fear and Loathing in my
Timb227's Avatar
Changing the bulbs are a pain, becasue you have to take the bumper off, and then remove each headlight in order to change the bulb. It's easy if you have taken the bumper and headlights off before but still takes some time.
Old 03-28-2010, 08:41 PM
RjG2's Avatar
Not to jack your thread but does anyone know if the oem hid ballast can handle a brighter bulb? Or do you have change everything if you want to go brighter?
Old 03-28-2010, 10:28 PM
Slythslyr
spcslyusarmy's Avatar
^^^^as long as the bulb wattage is the same you should be fine...
Old 03-28-2010, 11:30 PM
Acura TL 04, G37s 19"
eduardmc's Avatar
I WAS ABLE TO REPLACE THE BULBS WITHOUT REMOVING THE BUMPER OR INNER FENDER. READ MY TREAD IT WILL GIVE YOU AN IDEA HOW TO DO IT. THE ONLY THING I HAD TO REMOVE WAS THE BATTERY , VERY EASY CHANGE.
https://acurazine.com/forums/3g-tl-problems-fixes-114/i-changed-my-ds2-bulb-without-removing-bumper-side-fender-769286/
Old 03-24-2015, 12:57 PM
2006 Acura TL AT
Brooks Hoy's Avatar
06 bulb replacement
ANybody have a step by step for replacing headlight bulb for 2006 acura TL. ive only found 2004-2005 threads. Also, leave bumper on? or take it off?
Old 03-24-2015, 01:05 PM
dezymond's Avatar
I ended up taking my bumper off and even had to take out the housing a bit to get my hand to be able to maneuver to put in the new bulb. It's not easy, but it's not difficult either, just time consuming.
Old 03-24-2015, 01:54 PM
2006 Acura TL AT
Brooks Hoy's Avatar
your link is gone, do you have another one?
Old 03-24-2015, 02:19 PM
2006 Acura TL AT
Brooks Hoy's Avatar
when you say housing, do you mean the entire headlight assembly?
Old 03-24-2015, 02:28 PM
dezymond's Avatar
yes. sorry headlight assembly is more accurate.
Brooks Hoy (03-24-2015)
Old 03-24-2015, 02:31 PM
2006 Acura TL AT
Brooks Hoy's Avatar
for both driver and passenger? or just driver? also, would removing the battery give the same effect as removing the headlight assembly? as far as extra space
Old 03-24-2015, 03:25 PM
Registered Bunny
polobunny's Avatar
Received 1,073 Likes on 892 Posts
https://acurazine.com/forums/third-g...4/#post8285704
Still valid, really. First link or second link, depending if you want to do it the Acura way or the crafty way by the wheel well. Topic has been beaten to death already.
Old 03-24-2015, 03:27 PM
dezymond's Avatar
If I recall, I removed most of the headlight assembly but wasn't able to fully take it out due to the intake system. I just moved it enough to make access to the light bulb easier. Can be a bit of a pain to do, but it's easy enough.
I don't recall removing the battery making it any easier to access, for me at least. That's why I went through the trouble of taking the bumper off and then unscrewing the headlight assembly enough to move it.
Old 03-25-2015, 09:13 AM
vietxquangstah's Avatar
I tried to do the passenger side and drivers side through the wheel well and it wasn't working out for me. I got frustrated and just ended up removing my bumper and taking the headlights out.
I spent so long trying to do both drivers and passenger side through that wheel well that now I have condensation in my headlights. I was able to remove the bulb (it was hard) but couldn't put the new bulb back in and clip in place.
I probably spent a good 30 minutes on both sides and gave up and took the bumper off
Old 03-25-2015, 11:17 AM
RedStar101's Avatar
It's simple to remove the bumper, I wouldn't even try thru the wheel well.
sockr1
10-01-2015 01:31 AM
wusty23jd
09-24-2015 11:41 AM
brjones9
09-03-2015 07:30 PM
voigt
09-02-2015 10:44 PM
MyKids&Cars
09-01-2015 12:53 PM
Quick Reply: Replacing OEM D2S bulbs
