Trunk release button not working
Old 03-16-2009, 02:31 AM
2013 MDX
vi3tboi's Avatar
So i owned my TL for about a year now and in the beginning my trunk release button worked just fine until about a few months ago it just stopped working.. I checked the switch inside the glove box and that wasn't the problem.. the only way i can open my trunk is by the remote. Does anyone know whats the problem?
jason321 (04-06-2014)
Old 03-16-2009, 02:53 AM
I MAKE NO SENSE
tc_terencec's Avatar
My first guess would be an electrical problem, since the switch is electronic (someone correct me if I am wrong). Check to see if all the fuses are good. If the problem persists, maybe the harsh Edmonton winter has done something to the wires.
Old 03-16-2009, 11:11 PM
PeterUbers's Avatar
Has anyone installed any electronics recently in your car? (ex: remote starter, aftermarket alarm, etc) or for any reason taken down the lower dash (plastic cover beneath the steering column)?
If so, the trunk switch plug may have been disconnected and not re-plugged back in.
Old 03-17-2009, 12:46 AM
2013 MDX
vi3tboi's Avatar
yeah i had a alarm/starter installed before the winter and the button was working at the time.. and just one day it just didnt work again..
any advice would be helpful thanks
Old 03-17-2009, 01:16 AM
Registered but harmless
Will Y.'s Avatar
Reconnect the trunk button: post 9 onwards in https://acurazine.com/forums/3g-tl-problems-fixes-114/trunk-wont-pop-dash-button-713925/
Old 03-17-2009, 09:58 AM
Majofo's Avatar
- definitely check out the thread that Will posted.
Old 03-17-2009, 11:18 AM
PeterUbers's Avatar
LOL... there is a rash of trunk buttons not working in TL's and a rash of batteries not charging or dying in TL's lately....
Old 05-14-2009, 11:43 PM
USNA93's Avatar
Thanks all...you guys saved me a trip to the dealer...I didn't even know about that glove compartment switch. I guess I flipped it when I got the manual out. All's well.
Old 05-16-2009, 07:20 AM
Maddizm's Avatar
To the OP, the alarm guy probably didn't put it back on. Just gotta go up into your panels and reconnect it.
Old 05-25-2009, 05:27 AM
jayjay36's Avatar
I had the same issue with my car & still haven't resolved the issue
Old 05-28-2009, 04:00 PM
aliang01's Avatar
I have a stock KBP TL-S and I too had my trunk release gone bad. Very very odd, it almost seems like these problems are 'timed' to go off. Anyhow, in the dealership getting fixed. Will post after I get it back.
Old 05-31-2009, 12:41 PM
2013 MDX
vi3tboi's Avatar
please let me know how they fixed it and did they charge you for the fix.. thanks
Old 07-15-2009, 09:01 PM
misu3108's Avatar
HELP please!!
I have an 2004 TL and I noticed that the trunk release doesn't work from within the car and I also checked for that switch in the glove compartment and it's on. If I take the key out from ignition and then press the trunk open button I HAVE TO MANUALLY open the trunk cause it's not popping up. I also noticed a that if I press my hand on the trunk when it's closed it balances up and down a little bit. It's like the lock doesn't hold it tight no more.
Please if anyone knows how to fix it let me know.
PS. I also read somewhere that it might be the actuator
Thankx Dan.
Old 02-20-2014, 02:33 PM
2ndidgirl's Avatar
I Had the same problem and the switch in the glove box had been moved to off. Now it works and problem solved
Old 04-06-2014, 11:27 PM
jason321's Avatar
I had the same problem for over a month, and I thought there must be some connection problems. Well, thanks guys, now I know there is a switch in the glove box.
Old 07-30-2014, 03:48 PM
jkcutter's Avatar
Hello,
I'm glad the original poster found that the valet switch solved his problem. For others who might have a problem with their trunk release that the valet switch doesn't solve...
My 2005 TL's trunk release became intermittent. When I pressed either the dash button or the key fob button, the release made no sound. I suspected an electrical problem.
After ensuring that valet switch in the glove compartment was ON, the owner of an electrical shop advised me to lubricate the release mechanism before doing any electrical troubleshooting. I didn’t think that would work, because there was no indication that there was any power to the release; but I tried lubrication anyway.
I filled all the cavities of the release with white lithium grease, and worked the mechanism back and forth many times.
To my surprise, that solved the problem. Now, the trunk opens every time.
Good luck!
leedogg (04-19-2017)
Old 02-12-2015, 02:52 PM
Q('.')=O
imj0257's Avatar
Took my car to get serviced and when I got back I noticed my trunk button in my car didn't work but my keyfob button did.
I checked the valet switch in the glove box and.. well there is no switch.
Do I need to order and install that part? If so is it easy and will it fix my problem? Or is there maybe a fuse or something that needs to be replaced. I honestly don't care if the switch is there or not, I just want the trunk button to work.
Old 02-12-2015, 03:12 PM
Registered Bunny
polobunny's Avatar
Received 1,073 Likes on 892 Posts
Left side of page. Want to be cheap and not pay for a switch? Bridge 1 & 2 together using anything conductive.
Otherwise part number is 35810-SEP-A01, price under $10.
smsTL (08-23-2017)
Old 02-14-2015, 10:59 AM
Q('.')=O
imj0257's Avatar
Nevermind. The switch fell behind the dash when changing out the air filter.
Old 02-03-2017, 12:19 PM
Q('.')=O
imj0257's Avatar
Shit. Replaced the cabin filter again and this time the trunk switch flew off and no idea where it is. Looks like I'll have to order a replacement this time
Old 02-03-2017, 12:25 PM
Majofo's Avatar
csb
Old 02-03-2017, 02:18 PM
BreezyTL's Avatar
I have a switch from my part out. Let me know if you haven't sourced a new one yet.
Old 02-03-2017, 03:30 PM
Received 8,584 Likes on 6,630 Posts
Originally Posted by imj0257
shit. Replaced the cabin filter again and this time the trunk switch flew off and no idea where it is. Looks like i'll have to order a replacement this time
Originally Posted by polobunny
want to be cheap and not pay for a switch? Bridge 1 & 2 together using anything conductive.
otherwise part number is 35810-sep-a01, price under $10.
Old 02-26-2017, 12:29 PM
jean's Avatar
Thank-you once again Acurazine and the search function...
Ive been without my trunk release button for all of last summer...
it was the switch in the glove box..
Cheers
J.
Old 04-19-2017, 11:34 AM
RAR
leedogg's Avatar
Received 1,286 Likes on 714 Posts
Originally Posted by jkcutter
Hello,
Good luck!
Fantastic. That did the trick for me. Also, I think it might have fixed my trunk light issue. My symptoms were an intermittently working trunk button and trunk light that were both degrading. I believe the light issue was related because the mechanism for turning on the light is part of the trunk opening mechanism. This makes sense as dirt builds up in there and freezes things up.
acurajj
09-19-2015 03:47 PM
PortlandRL
09-14-2015 12:01 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
Quick Reply: Trunk release button not working
