KAIXEN HID Kit Groupbuy
This is an Acurazine Special Pricing Event for the KAIXEN HID Conversion Kit and the KAIXEN HID upgrade bulbs. Kaixen is an ISO 9001 certified manufacturer that develops and builds its own components (unlike some companies that buy them from China and re-assemble it). It currently holds E13, TUV, and QS9000 quality certifications. It is the only other company in the world (other than Phillips) to have developed the diamond-shape bulbs.
Kaixen HID kits were first sold using Philips/Matshushita ballasts and bulbs starting in 1999. Since then, Kaixen has recieved its own license as well as hiring several key engineers from Germany to develop its own high quality ballast / bulbs since 2002. As stated above, KAIXEN is the only other company other than Philips to develop the diamond-cut bulbs. Kaixen is ISO2001 registered, E13 certified, and KQA quality assurance certified. All kits are made direct from the factory, and are not "rebased" as most Philips HID kits are made. The HID kits come with 1-year full replacement warranty.
There are four different colors: 5,000K (Natural White), 6,000K (Extreme White with a hint of blue), 6,500K (Extreme White w/ a hint of purple, 8,500K (Extreme Blue), and 3200K (Yellow).The yellow kit is $45 more and the double type kits are $85 more. Here are the different types of bulbs: H1, H3, H4S, H7, H11, 9003, 9004, 9005, 9006, 9007, 881. The kit comes with everything you need. All Kaixen upgrade system are designed for direct replacement with no need for additional parts or wiring.
The KAIXEN HID D2C upgrade bulbs come in 6000K, 65000K, and 8500K.
Here's a comparison between OEM and KAIXEN's 6000K HID Kit.
The following payment terms are accepted: Bank or Teller Check, Money Order, sent to:
Excelerate LLC
998 West Main St
Branford, CT 06405
You may also send payment to Excelerate@sbcglobal.net via Paypal. However, if you pay through Paypal you must add 3% to the transaction.
Shipping times will depend upon your location. Prices based on shipping to 48 continental states in the U.S.
Order anytime!! Prices will run as follows.
KAIXEN HID Kit - $300 shipped
KAIXEN HID Upgrade Bulbs (Pair) - $150 shipped
AIM Screen Name: Excelerate04
E-mail: Excelerate@sbcglobal.net
or PM me.
RETURN POLICY
- ALL RETURNED AND/OR CANCELLED ORDERS ARE SUBJECT TO A 25% RE-STOCKING FEE PLUS ALL SHIPPING CHARGES (Includes original and return S&H fees).
- ALL AUTHORIZED RETURN MERCHANDISE MUST BE NEW, UNUSED, AND IN ITS ORIGINAL PA CKAGING. ALL DOCUMENTATION, WARRANTY CARDS, INSTRUCTIONS, AND HARDWARE MUST ALSO BE RETURNED.
- ITEMS MAY BE RETURNED WITHIN 15 CALENDAR DAYS FROM THE RECEIPT OF MERCHANDISE.
- SPECIAL ORDERS ARE NOT RETURNABLE.
- ALL DEPOSITS ARE NON-REFUNDABLE.
EXCELERATE LLC
998 West Main St
Branford, CT 06405
(P) 203-483-6100 (F) 203-483-6101
www.ExceleratePerformance.com
Joshua Lockwood
Owner
Excelerate LLC
998 West Main St
Branford, CT 06405
or PM me.
RETURN POLICY
EXCELERATE LLC
998 West Main St
Branford, CT 06405
Joshua Lockwood
Owner
Originally Posted by hybridnrg
my KAIXEN HID Kit is 7500k. Can i get the 6000k blub? Everything would be plug in play right. will it work?
how handsome I am
so Im looking at these and cant help but ask how it is that the kelvins work.. i mean, Im under the impression that the lower the K the whiter the light and the higher the output.. 4300k~ is pure white and has best output (which is what I would like) but you say that 6k is white... then that 6500k is purple? I thought that was anything around 9000k and up that you started seeing purple.. then 8500k blue?
Still going to buy, just want a bit more info!
You hit the board during HID fever. Seems like everyone wants to change their lights these days. How big of a difference will it be over stock? Is this just a "take old bulbs out, put new ones in" or am I going to have to do some dirty work? If its that simple, put me down for some 6000k Whites.
how handsome I am
Degrees K = ONLY COLOR
Lumen= BRIGHTNESS
Also look here for more info: http://www.jwspeaker.com/hid_information.htm
GroundedCustom (01-23-2016)
Yo, Those are hot, but Ive seen some that are even hotter, I seen a CL-s That had 14,000K Crystal Purple hid lights, that joint looked on point! I really like the purple look! That 6,500K purple looks on point, I might have to consider, Im thinking.....
i might jump on this as well, excel, i'm waitin to hear back from morette for my headlights (for my subaru)...i'll let you know as soon as i find out from them what's up. more than likely it'll be either 6500k purple kit or 6000k white kit and possibly bulbs for my CL
Professional Newbie
i'd be worried about getting condensation in my headlight during the install, is that likely? and if it happens, i'm sure acura wont fix it under warranty
some more info
* Up to three times less wattage is used (HID = 35w, halogen = 55-100w)
* Up to four times more bright light produced (HID = 2400-3200lu, halogen = 800-1700lu)
* Up to ten times more intense light produced (HID = 202,500cd, halogen = 21,000cd)
* Up to six times longer lifespan (HID = 2500hr, halogen = 400hr)
* HID light contains less infrared and ultraviolet light, which fatigues the driver and surrounding motorists
* HID light illuminates the road with better contrast and more lifelike tones of color
* Halogen filaments naturally produce a color of 2300K to 4000K (2300K is yellowish, 4000K is whitish) Anything bluer requires the use of light-dimming color filters
* HID produces a natural color of 4100K to 6000K (4100K is daylight white, and 6000K is slightly bluish white) Anything bluer requires the use of light-dimming color filters
* HID has low lumen maintenance, meaning bulbs do not dim down as much towards the end of their lives
* HID has high flux properties, meaning light is very evenly distributed when installed properly
Originally Posted by PixelHarmony
So other than just adding color, these are functionally as effective as our current stock bulbs (as far as brightness)?
Originally Posted by ATXCLS
I would love to order two sets-just trying to see what funds are going to look like in the coming days.
Originally Posted by CleanCL
i'm trying to muster up some more people... a lot are interested, we may get more than 5 orders. just letting you know. i want my HIDs lol.
Master Graphic Artist
Originally Posted by Excelerate
If you just have regular halogen bulbs right now, then you will notice a huge difference in the way the road is illuminated. If you have HID's from the factory the light will be slightly brighter and the color will change.
Scru U guyz, Im Goin Home
I have a TSX, and it was to my understanding that the TSX has one of the best HID's out on the market. So I guess the color of the HID is what we are buying. Maybe I'll convince my friend to pick these up.
