2011 TL AWD model AC issue
Old 08-26-2014, 01:41 PM
jdk714's Avatar
I have issue with my AC system. the blower motor keep runing crazy ( high speed) with hot air blow from front winshield. Can't control on AC console, press On/oFF, speed fan nothing. hit A/C button is engage. Anyone can't help me on this issue. Thanks.
Old 08-27-2014, 06:39 AM
Keeping TL until 2029
echodigital's Avatar
Did you hit the Auto button?, hit the fan location to cycle past Auto setting.
Old 08-27-2014, 11:46 AM
'20 TLX SH-AWD A-Spec
Tonyware's Avatar
There is a self-diagnostic function for the HVAC. To run the self-diagnostic function, do the following:
1. Turn the ignition switch to LOCK (0) and then back to ON (II), or press the engine start/stop button to select the OFF mode and then the ON mode
2. Press and hold the FAN ON/OFF button, then within 10 seconds press and release the REAR WINDOW DEFOGGER/MIRROR DEFOGGER button five times Release the FAN ON/OFF button, then the self diagnostic begins.
If there is a problem with the system, it will flash AUTO, 88 and AUTO, 88 and WINDSHIELD DEFROST, or 88 and MODE. If there is more than one problems, they are displayed one at a time in sequence followed by a pause. If there are no problems detected, the segments do not illuminate, and the system appears to be turned off. The problems are displayed with some codes you may need to take it to the dealer to repair. There are lots of codes!!! If you have codes and you can post them I may be able to interpret them for you.
To cancel the self-diagnostic turn the ignition switch to LOCK (0), or press the engine start/stop button to select the OFF mode.
Hope that helps.
echodigital (08-28-2014)
Old 08-28-2014, 09:53 AM
Thanks for that tip!
Old 08-30-2014, 12:41 AM
jdk714's Avatar
do you have diagram how to remove/install Air Temperature Control Blend Door for 2011 acura tl ?
Old 08-30-2014, 04:41 AM
Tonyware's Avatar
There are two of them. One for passenger side and one for driver side.
The shop repair manual was posted here, a while back: https://acurazine.com/forums/4g-tl-2009-2014-123/acura-tl-service-manual-899572/
Its on page 21-100.
Old 11-18-2014, 09:26 AM
Ephi82's Avatar
Hope that helps.
That was very helpful
When I ran the test, it displayed Auto then 88, Auto then defroster and it repeated that cycle again and again. Does that mean there is a problem(s) ?
Old 11-28-2022, 04:39 PM
KidK's Avatar
Hope that helps.
Thank you. I get “auto”, “88”, “||” and the Defrost sign. Thoughts as to an easy fix? Thank you.
hues10
1G RDX (2007-2012)
09-07-2016 03:47 PM
Legend2TL
Motorsports News
01-31-2016 09:27 AM
Mr.Tea
1/2G MDX (2001-2013)
26
10-09-2015 04:27 PM
aces2412
3G MDX (2014-2020)
09-07-2015 08:40 PM
Snafunk
09-03-2015 08:01 PM
Quick Reply: 2011 TL AWD model AC issue
