Yungone501's- Excessive infatuation with the J-series
Old 01-28-2013, 04:57 PM
  #121
J-series addict
yungone501's Avatar
Got the TL-S cluster almost all the way completed. Few more things to do but here's the progress:
Old 01-28-2013, 07:49 PM
  #122
Atlas.46's Avatar
Looking good
Old 01-28-2013, 10:28 PM
  #123
J-series addict
yungone501's Avatar
Strut tower painted to match manifold accent. I know, its a little lame to be posting but it came out so good that I figured why not? It was a slow day at work and I had some free time...and a can of ceramic paint.
Oh and disregard my makeshift CAI...its a temporary piece. If you look close enough, it still has a nitrous nozzle still attached to it. I should probably remove that as its tempting...
Old 01-29-2013, 04:13 AM
  #124
Atlas.46's Avatar
a 50 shot wont hurt right...lol
Old 01-29-2013, 07:35 AM
  #125
Sweet. I need to start looking for my wiring stuff.
Old 01-29-2013, 11:57 AM
  #126
3.7L Nitrous Breathing CL
richardparker's Avatar
Does this motor have a differnt belt routing than earlier j's ?
Looks weird seeing the long stretch between the power steering pump and the alt and no seperate ps belt.
I like the color matching of the strut bar,now you are going to have to re color the odd color piece's to blend in. Blacks and polished pieces and it's will be nice to look at.
Once you have run nitrous,in the back of your mind you will alway want to run it.
keep it.
Old 01-29-2013, 12:10 PM
  #127
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,414 Likes on 3,024 Posts
God I want this car
Old 01-29-2013, 02:37 PM
  #128
J-series addict
yungone501's Avatar
That's what everyone says...at first.
Ok.
keep it.
Dang Mr. I Observe Everything I See, lol. Yes, it has the AC compressor deleted therefore the belt is routed in a manner where it can still be held under the belt tensioner.
God I want this car
You already have one. Just need a j35a8 and you're gtg!
Old 02-02-2013, 05:05 PM
  #129
J-series addict
yungone501's Avatar
Coil packs painted to match.
Big plans fast approaching on adding turbo. Car will be taken to a shop next week to build the manifold and I'm going to do everything else. This is my first turbo build/setup so I will require help I'm sure along the way from those who are experienced and knowledgable.
Old 02-02-2013, 08:00 PM
  #130
It's going to be beast boosted
Old 02-03-2013, 09:49 AM
  #131
Lone Wolf
brian6speed's Avatar
I was just reading thru paul's turbo build thread on v 6 p forum. A lot of useful info with pics if you haven't already read it.
Old 02-03-2013, 11:20 AM
  #132
@Mikeshlong On IG
mikebikelife's Avatar
I like boost ...
Old 02-03-2013, 11:24 AM
  #133
J-series addict
yungone501's Avatar
I honestly think I've seen them all. I'm one of the biggest researchers you've ever seen. Google becomes your best friend on situations like these...helps to make things a little easier with unique or custom builds.
I've already ordered Richies V3 PCDs and was able to order just half of them so that I could use them as the beginning of a turbo manifold. They're 304 stainless which is good because I want all of the hot charge tubing to be entirely stainless.
I think doing a turbo setup is going to be just as much work if not more than the j35a8 swap itself. There's a lot that goes into this stuff. But, it's ok. Old dudes like me need to have their fun too!
Old 02-04-2013, 04:37 AM
  #134
Atlas.46's Avatar
you ordered half of the pcds... hmm... i would be interested in seeing your manifolds.
Old 02-04-2013, 10:10 AM
  #135
(Mid-Atlantic)
God I want this swap
fixed
Old 02-07-2013, 07:12 PM
  #136
J-series addict
yungone501's Avatar
As mentioned, I had two choices on manifold design. The first option was Richies V3 PCDs that consisted of the upper portion only. The upper flange surprised me in its design quality as it was a cast piece...meaning it was made like an engine block is made. That's basically where molten steel is poured into a cast where it then cools to produce a solid, one piece structure which is generally better than welding multiple pieces of steel together which leaves more room for failure from cracked welds. That's the (biggest) advantage. What I don't like about them is that they are 304 stainless which is more prone to cracking from heat fluctuation. Here's a picture of what they look like...fitment was perfect.
Old 02-07-2013, 08:10 PM
  #137
HTX_Acura's Avatar
pretty badass swap!
Old 02-07-2013, 11:51 PM
  #138
Glacier Frost Mica CL-S
INSPIRE 32V's Avatar
looking good
Old 02-08-2013, 04:23 AM
  #139
Atlas.46's Avatar
How much did these run you ? if you dont mind me asking.. Twin turbo setup with some T25s or T28s internally gated.
Old 02-08-2013, 07:40 AM
  #140
J-series addict
yungone501's Avatar
I paid $150 shipped for the pair on the upper PCD flanges. Great deal. Great product.
Old 02-08-2013, 08:19 AM
  #141
J-series addict
yungone501's Avatar
Was planing on doing this second part lastnight but ended up passing out after posting the PCD flange.
My second option is the one I may be leaning towards. The P2R flange is a mild steel piece that's approx 3/8" thick. It's meant to be the start of an exhaust manifold and allows flexibility to go any direction/route desired rather than a predetermined one. I found a company called Spin Tech Mufflers based out of Cali that bends/builds custom exhaust components and ordereded a set of 90 degree horizontal oval to round transitions. Even though the name describes what it does, I'll break that down. It's basically a 90 degree piece of tubing that will convert the oval shape of the exhaust port from the cylinder heads in to a round shape but also allows me to take a horizontal path straight from the head to where the turbo will be mounted (where battery currently sits). It's a 3.5" radius bend meaning it changes the direction of the tubing within that distance which is basically from the head to the bends elbow. Haven't received them yet but they will be here by Tuesday and I will post pictures then. Here's the P2R flanges:
Old 02-12-2013, 03:27 PM
  #142
HickamHatch's Avatar
I think I like these more than the cast pieces
Old 02-12-2013, 04:07 PM
  #143
R2D
R2D's Avatar
this was a very nice build! wish to one day do this
Old 02-12-2013, 10:32 PM
  #144
J-series addict
yungone501's Avatar
Car is at this guys ^^^ shop right now getting "tweaked".
Maybe he will bless us with pictures of progress...huh Matt?
Old 02-13-2013, 01:41 PM
  #145
bmeyer's Avatar
@yungone501
When you did the wiring for the car, what did you end up doing for the fuel pump control wires on the E plug? (Assuming of course that you didn't install the controller from the TL-S)
I'm considering attempting an ECU upgrade in my '05, but there are a few items like this on the newer ECUs that are putting me off a bit.
Old 02-13-2013, 02:10 PM
  #146
Americandream's Avatar
Thats a sexy build, props to you sir!
Old 02-13-2013, 02:40 PM
  #147
I will send the pics to you as progress is made and you can do as you wish with them
Old 02-13-2013, 04:13 PM
  #148
ArcticFlyer's Avatar
Hello! Did you ever weigh the bare J35a (no trans)? With or without starter, elternator, etc.?
Old 02-13-2013, 08:20 PM
  #149
J-series addict
yungone501's Avatar
Originally Posted by bmeyer
@yungone501
For me, I wired them up to the fuel pump control (FPC) module. Its a 2-wire pulse width modulation controlled unit...aside from the standard power and ground ran to the fuel pump. As previously explained a page or two back, I built a hybrid fuel pump out of an 05 RL and the 98 Accord assemblies. I had to use the Accords fuel pump assembly body and installed the RLs internals inside of it. This was necessary because the RL (as well as the 07-08 TL-S) fuel pump assembly was about half the height of the Accords. The fuel level float was also modified to work in the Accords fuel tank as I am using an 07 TL cluster.
As for you, just so you know, running the FPC module is NOT required to run the motor of your TL but is necessary if you want a MIL free conversion. Not sure of the exact differences between the two (3g TL-S and TL) off the top of my head but any differences you notice, Id be happy to help or assist with any questions you may have. Just PM me if its gets too lengthy to keep the thread clean.
I will tell you that your conversion will be difficult and not so sure its possible because of the major differences between the transmissions...unless youre running a 6MT.
She's quite a lady, thanks.
That's good enough for me. Just as long as we can observe from a distance and stay out of your way.
Hello! Sure didnt...I dont have a scale in that range. Sorry. But I will say that the j35a8 must be ATLEAST 25lbs lighter in weight than a j32a2 fully assembled. The difference is primarily in the magnesium intake manifold. Not to mention other various points at which Acura went with lighter and stronger parts for this motor.
Old 02-14-2013, 01:34 AM
  #150
Atlas.46's Avatar
wait your on here..
his fab work and attention to detail is great. What are the dimension of the opening on the cast pieces(not at the flange) ?
Old 02-14-2013, 10:39 AM
  #151
wait your on here..
for a couple years, yes. Just don't post much
And thanks, I try
Not sure of dimension of cast piece off the top of my head
Old 02-14-2013, 06:18 PM
  #152
J-series addict
yungone501's Avatar
Atlas, if you're asking about the OD of the PCD outlet, I'm quite certain it's 2.25".
Old 02-14-2013, 09:02 PM
  #153
Atlas.46's Avatar
Hmmmm...
Old 02-14-2013, 09:49 PM
  #154
J-series addict
yungone501's Avatar
Hmmmm...
Mmmhmm...
gerzand (02-14-2013)
Old 02-15-2013, 12:58 AM
  #155
Atlas.46's Avatar
Mmmhmm...
i thought i edited that. Has Matt sent you pics of the oval to round piping you ordered ? Or manifold progress?
Old 02-15-2013, 07:20 AM
  #156
J-series addict
yungone501's Avatar
No pictures as of yet but he called me lastnight and informed me that they had arrived. If they're anything like the first pieces Spin Tech sent then they should have very impressive bend quality with not a kink one.
Btw, what's up your sleeve Atlas? Droppin' hints like bombs buddy.
Old 02-15-2013, 07:32 PM
  #157
J-series addict
yungone501's Avatar
I'll be removing the UNsporty, heavy Accord cloth seats and installing a set of RSX Type S seats. Black leather and manual operation not only looks better but will save a little weight. I'll see about weighing them individually when exchanging them. The drivers seat (shown) cost me a whopping $48.
Old 02-15-2013, 07:44 PM
  #158
J-series addict
yungone501's Avatar
Forgot to add something:
The original intent of this thread was to modify a j35a6 (2nd gen j-motor) to work with the factory electronics of a 1st gen j-motor but kind of derailed upon the find of the j35a8 which then of course totally blossomed into an entirely new idea (the Accord).
Now that Mr Hickam has my dearly beloved, I began to feel very bored driving my wife's 4cyl. 1998 CL so I rekindled the original thought process here in the thread. I last ended with needing to modify the oil pump so that when mounted to the engine, it would properly seal and not leak oil. Shown below is that taking place and now I'm ready to move along to the next step:
Here's the same oil pump shown earlier in the thread but now with the mounting surface welded to match the j35a6's oil pumps mating surface.
Next, I had the weld milled down to the mating surface itself and this enables me to finally mount the pump:
Old 02-15-2013, 08:10 PM
  #159
Old 02-16-2013, 10:46 AM
  #160
@Mikeshlong On IG
Impressive .
Quick Reply: Yungone501's- Excessive infatuation with the J-series
