IT WORKS!!! Use navi touchscreen on PC via USB!!!
Old 11-13-2006, 07:17 PM
tejesh83's Avatar
what scan converter did you use?
Old 11-13-2006, 08:56 PM
'06 NBP : 6MT : NAVI
met152's Avatar
Scan DO 800
Scan Do 800 (which is model 1270, I think).
Here's the user's manual
www.commspecial.com/manuals/mn-1270.pdf
Although not listed in the manual, it requires a 5V 3A power supply. I used the 5V line from my M2-ATX power supply.
Old 01-10-2007, 06:06 PM
met152's Avatar
Exclamation Carpc Installation Complete!!!
The installation is complete and pics have been uploaded.
Please don't post new items in this thread, but refer to the new one below
https://acurazine.com/forums/console-computer-gaming-13/socom-ii-official-thread-121256/#post1629607
Thanks!!!
Old 01-12-2007, 03:46 AM
drkangel348's Avatar
Wow... Very nice! Thanks for sharing your insight.
Old 01-26-2007, 03:24 PM
GIVER's Avatar
Simply an incredible mod. Great job.
Old 02-14-2007, 05:43 AM
x-mode007's Avatar
Hey ITL... I wanted to know if you have started with your friends stock navi with doing this mod..... I wanted to redo my carputer and move to this type of setup. I don't know if you remember but I am the guy with a screen in the center armrest, we met at Ed voyles.
Old 02-14-2007, 09:05 AM
  #47
ITL
I do my own work.
ITL's Avatar
no, I haven't. He has some other priorities for the moment and is putting this one on the back burner for a while.
I do remember you and your ride. PM me and we can talk more through that channel.
Old 08-29-2007, 04:54 AM
kookiemonster412's Avatar
Originally Posted by met152
thanks Zax,
Yeah, it was a decent amount of work. First I had to build a small module that would allow me to switch between the stock function and the usb controller. This required some guesswork as to the right size connectors and cables to order from digikey.
The touchscreen uses a 4-wire resistive panel that goes into the touchscreen display board (board behind the lcd screen). This goes out on a flat flexible cable (FFC). My module takes in that signal in through a FFC conector, and passes it through the NC contacts of a 4PDT relay, and then back out to the stock display board. The NO contacts of the board are fed into a USB touchscreen controller. When the relay is de-energized, the screen acts like it does from the factory. When the relay is energized, the touchscreen coordinates are only sent to the USB controller.
The only physical modification that I made to the stock hardware, was some cutting of the metal cover on the back of the display unit. This allowed the FFC from the touchscreen to reach my module. I can remove this module and return everything to stock, of course minus the cutting. It would be possible to do this without cutting, but you'd need to extend the flat cable to reach the module (I didn't have the ability to do this at the time and I didn't mind cutting)
This shows where I cut.
To answer your other question zax, I am going to get video on the screen using a scan converter that will convert VGA to RGBs at the 15kHz frequency required by the navi lcd. I will be doing this using a piece of hardware made by Communications Specialists (I think that's their name). It's the "Scan DO 800"
This conversion should give me the best possible display on the stock screen. It won't be great due to the low resolution of the lcd, but it will be better than using the RCA input on the Dom's unit.
I don't have the PC that I'll be using yet, but it will probably be based on a VIA mini-itx mainboard in an enclosure in the trunk. I already have a usb gps receiver to use with Iguidance or some other pc based navigation software. I might look into feeding data from the Acura gps receiver, but I'm not sure how difficult this would be.
Here are all the pictures I took. Looking back, I should have taken more.
Please let me know if you have any questions whatsoever. If anyone is interested in doing this themself, please let me know if I can help. I can send you a list of all the parts (and the $$ of all) that you'll need.
I thought about making a module to sell, but I doubt many would be comfortable doing this. And if they were comfortable doing this, then they'd be able to make their own just as easy.
You can email me at: mike at mtatko dot com
Met, thanx for the great setup! However, I have been reading this over and over ( perhaps im not reading it right), but i am very confused on how to get a video signal with the scan converter. where would you tap and run the wire from the Navi to the Scan Converter?. Is there a diagram or pointer you can give me to complete this Mod? Everything else I can understand very clear, but except for that.
Thanx
Old 04-07-2009, 03:21 PM
  #49
2006 ASM tsx
vthree's Avatar
would this be at all applicable to an 06 tsx navi unit???
Old 04-07-2009, 03:53 PM
  #50
1st TL-S on air in
wrxyboy's Avatar
yes this would be since i am assuming the the TSX has a touchscreen, look at a recently done TL. Concept is the same but you would need to take apart the TSX screen to see if the touchscreen is 4 pin or 5 pin and buy the corresponding USB controller. https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/visualogic-vmod-media-demand-709051/
Old 04-26-2010, 09:42 PM
  #51
goalwong's Avatar
wow......
Old 07-16-2010, 10:20 PM
  #52
OCD
Roger555's Avatar
need to do this soon you guys still around incase I need help?
Old 01-14-2011, 08:48 AM
  #53
falkien's Avatar
Now let's get this working and we will be golden!!!
http://www.engadget.com/2011/01/13/c...-carputer-dre/
Old 04-08-2011, 04:31 PM
  #54
I need a car in
thait's Avatar
sorry to bring back a old topic but im going to attempt to do this to my car. is they any update on this?
Old 04-08-2011, 05:55 PM
  #55
OCD
Roger555's Avatar
Ya I need to tackle my system sometime but with all the tablets out these days carPCs are getting even less support I'd rather run Android then windows XP or windows 7. I'm not sure what to do
Old 04-09-2011, 12:19 AM
  #56
Being an Acha Bacha in
Elegant TYPE S's Avatar
Honestly it would be easier to just mold in an iPad.
Old 04-09-2011, 07:06 AM
  #57
KN_TL's Avatar
If you want to maintain the factory nav system then this is the only way to go. I am going to be doing this eventually pretty much like the OP did. The only thing you have to be concerned with is add resistance to the circuit since it is a 4 wire resistive touch screen.
Old 04-09-2011, 08:54 AM
  #58
OCD
Roger555's Avatar
Factory Nav I dont care about because google nav is 5 million time better. I do still need the trip computer and the integration wit the stereo though.
Old 04-14-2011, 05:44 PM
  #59
dwb993's Avatar
I am actually very close to doing this. I have the CarPC powered up and installed in the trunk using a BT Logitech keyboard for control. I have made the relay unit following Roger555's great schematic. Its all just waiting for a nice weekend with no kids to pull the dash apart and install it.
My question is about the "add resistance to the circuit since it is a 4 wire resistive touch screen." Can someone elaborate? I have seen nothing about this in either Met152 or wrxyboy's threads on this interface.
Old 04-14-2011, 05:51 PM
  #60
csmeance's Avatar
You could instead do what I suggested a while back and take out the factory LCD screen (only the LCD) and put in a much better high res display. You can buy a converter to convert the navi signal into a regular RCA video ouput and plug that into your new screen and use the joystick to control the navi/trip computer/audio. No loss of any functions either!
I used a touch-screen controller with a relay just like met152 did and there wasn't an issue for a while until the controllers kept on breaking. I think KN_TL meant there reverse and meant to say that you don't ADD resistance to the system otherwise the controller won't work
Old 04-14-2011, 06:19 PM
  #61
OCD
Roger555's Avatar
What is going out on your controllers, do you know? How many have failed ? If you have a failed controller I would like to look it over if would send it I would pay for shipping.
Also does the relay your using have a protection diode installed? Some relays come with them inside but some do not. Without a diode going across from (-) to (+) terminal of the relay each time the relay is activated/deactivated there is a huge voltage spike that will damage sensitive components.
"Current flowing through a relay coil creates a magnetic field which collapses suddenly when the current is switched off. The sudden collapse of the magnetic field induces a brief high voltage across the relay coil which is very likely to damage transistors and ICs. The protection diode allows the induced voltage to drive a brief current through the coil (and diode) so the magnetic field dies away quickly rather than instantly. This prevents the induced voltage becoming high enough to cause damage to transistors and ICs. "
Just do a search on the subject if you want to learn more!
Old 04-15-2011, 05:45 PM
  #62
dwb993's Avatar
I'm using a different relay than that. I used this diagram to wire it up, if you remember:
using this relay:
RELAY PWR 3A 4PDT 12VDC QTY (2)
http://search.digikey.com/scripts/Dk...l&name=Z186-ND
Do I need to install a diode on the relay?
Old 04-15-2011, 09:55 PM
  #63
OCD
Roger555's Avatar
The pic was just an example but check the lnk you posted its nit working for me. Unless the relay has one internally you need a diode going from 13 - 14
Ol'Dave
09-05-2020 02:56 PM
SilverJ
1/2G MDX (2001-2013)
09-21-2015 02:40 PM
acurajj
09-19-2015 03:47 PM
yahelou
09-06-2015 09:12 PM
Quick Reply: IT WORKS!!! Use navi touchscreen on PC via USB!!!
