'07 TL S Tail Lights on '06 TL
Old 07-09-2014, 01:49 PM
swanny708's Avatar
Hey I just bought a used 2006 Acura TL and I'd like to install the 2007 Acura TL Type-S tail lights. From what I understand, the lights fit but there is some wiring issues? Is there an installation guide somewhere that walks through each step? Does anyone have any before & after pictures?
I am considering purchasing these lights
http://www.1aauto.com/2007-08-acura-...G8gaAost8P8HAQ
Old 07-09-2014, 01:50 PM
all you have to do is swap LED boards from your old tail lights to the new tail lights.
then, bolt up the new tail lights to your TL.
finished!
The following 2 users liked this post by justnspace:
ggesq (07-09-2014), swanny708 (07-09-2014)
Old 07-09-2014, 02:01 PM
swanny708's Avatar
I've never personally done any modifications on my car and I don't want to screw anything up. How easy is it?
Old 07-09-2014, 02:06 PM
the rear bumper needs to be loosened a bit to where you can access some bolts for the tail lights.
this will be your biggest hurdle.
after that, un bolt the tail lights from the car.
when you have the tail lights off the car, you will see an LED board inside. unscrew the screws and take the LED board out.
now, place it into your brand new set of tails.
screw it in.
install tail lights onto rear of car.
tighten up bumper and you're good to go.
Old 07-09-2014, 02:36 PM
CLtotheTL32's Avatar
Received 9,495 Likes on 6,167 Posts
The 3G Garage has TONS of information gathered over the last 10 years. Take advantage of it
3G Garage: https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-service-department-aka-garage-questions-answers-check-here-first-553557/
Taillight Replacement DIY Thread: https://acurazine.com/forums/3g-tl-2004-2008-93/g-094-diy-installing-type-s-tail-lights-716996/
The following 5 users liked this post by CLtotheTL32:
ggesq (07-09-2014), justnspace (07-09-2014), ntmera (07-10-2014), Steven Bell (07-23-2014), swanny708 (07-09-2014)
Old 07-23-2014, 01:41 AM
sopmodm14's Avatar
dang, is there a youtube of this DIY ?
Old 07-23-2014, 04:23 PM
EvilVirus's Avatar
^ Its really not that difficult. I haven't seen a video on tail lights; you are going to have to search for that one if you can find one, but there is one for the rear bumper removal. The DIY link is straight forward. The only issue you may get is the led board as the plug is a bit tricky to remove the first time around.
Old 07-24-2014, 04:27 PM
tyintegra's Avatar
I did this to my 2005 years back and like others have said, the hardest part is getting the bumper off even with the DIYs.
It was my favorite mod of all and was completely worth it. The next mod that you should do is to get the Type-S rear fender lights that are grey instead of red. If you leave the red in, it just looks off next to the grey on the tail lights.
12-07-2020 05:39 PM
BoricuaTL
04-08-2016 01:08 PM
handsom-hustla
11-13-2015 05:04 PM
wusty23jd
09-24-2015 11:41 AM
brjones9
09-03-2015 07:30 PM
Quick Reply: '07 TL S Tail Lights on '06 TL
