HID Problem....
Old 07-26-2010, 12:56 PM
3.2TL
ThreePointTwoTeeEl's Avatar
Exclamation HID Problem....
My Passenger side HID comes on when I turn the lights on, but then turns off after a while. If I turn the lights off then on again, it'll come on but then shut off in a few minutes. The light is not pink.
Could it be the ballast?
Old 07-26-2010, 01:31 PM
Avant Garde Wheels
jjashaa's Avatar
or igniter..
swap bulbs left to right to be sure.
if the driver bulb on passenger side does same thing.. check igniters and ballasts..
so i'd try swapping those left to right too.
Old 07-26-2010, 04:34 PM
3.2TL
I know the ballast is a square box, but I've never seen an igniter.
how does it look? Where is it located?
I know I can get an HID kit for 60 bucks that comes with the bulbs and ballasts, but how about the igniter?
Old 07-26-2010, 05:26 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
ck with the sellers!!
swap bulbs as suggested,,pink on startup -when pointed at a wall- is ONE sign of impending failure
Flikker is another
So is weak output- one side to the other not same in brightness or color
replace bulbs in pairs or they do not match at all~
Old 07-26-2010, 05:27 PM
01tl4tl's Avatar
wiki HID and understand how the parts work together
If you have any moisture inside the housing lens- thats got to be fixed before a full repair of lights is made
Old 07-26-2010, 05:50 PM
Avant Garde Wheels
jjashaa's Avatar
#10 is the igniter
Part# 33129-S0K-A01
MilanoRedDashR
10-08-2015 10:30 AM
mshipon
2G CL Problems & Fixes
09-28-2015 12:14 PM
MilanoRedDashR
09-27-2015 10:15 PM
h22lude
09-27-2015 06:22 PM
Quick Reply: HID Problem....
