Is this normal for TL or any car
Old 09-08-2015, 07:35 PM
jliu6789's Avatar
https://youtu.be/FJZtc7bnZVw
my 2003 TL has some squeak noise from left read when driving. I jacked it up, with no parking brake applied, and rotate wheel, and there is this noise (see video) like brake pad in friction with disk when rotating.
then I found out the right rear wheel has the same issue. so is another TL.
is this normal ? I would expect it to be complete free of each other. also the disk surface is not that smooth.
Old 09-08-2015, 08:02 PM
Skirmich's Avatar
Received 1,016 Likes on 867 Posts
That is the incorrect installation of the brake pad shim.. You can confirm this by removing the wheel and looking at the outer-edge of the Rotor, You will see some marks indicating metal to metal contact.
Remove the brake caliper
Grab a Flat head Screwdriver
Push the Pad Shims retainers fully into the caliper bracket so it wont touch the rotor.
DONE.
jliu6789 (09-09-2015)
02-25-2020 09:57 AM
adreano17
09-16-2015 02:54 PM
kuzdu
09-10-2015 08:42 PM
Quick Reply: Is this normal for TL or any car
