Is this normal for TL or any car
https://youtu.be/FJZtc7bnZVw
my 2003 TL has some squeak noise from left read when driving. I jacked it up, with no parking brake applied, and rotate wheel, and there is this noise (see video) like brake pad in friction with disk when rotating. then I found out the right rear wheel has the same issue. so is another TL. is this normal ? I would expect it to be complete free of each other. also the disk surface is not that smooth. |
That is the incorrect installation of the brake pad shim.. You can confirm this by removing the wheel and looking at the outer-edge of the Rotor, You will see some marks indicating metal to metal contact.
Remove the brake caliper Grab a Flat head Screwdriver Push the Pad Shims retainers fully into the caliper bracket so it wont touch the rotor. DONE. |
