Intake troubles
Old 09-14-2015, 12:12 PM
Kevin Sami's Avatar
Intake troubles
Sooo, I removed my intake hose to clean my throttle and egr valve and I ran into an embarrassing issue... I'm having trouble reinstalling the intake hose lol. Any tricks or tips to get it back on? I'd remove the air box, but I have a couple seized screws(I was hoping it wouldn't be an issue)
Old 09-14-2015, 12:20 PM
Received 8,585 Likes on 6,631 Posts
elbow grease.. and make sure you loosed the clamp.
Old 09-14-2015, 01:06 PM
Skirmich's Avatar
Received 1,016 Likes on 867 Posts
Is a matter of angle most of it.. Grab it firmly and try to install it with an angle then giggle it to place. Dont try to install it directly flat because that is almost in-humanly possible.
Old 09-22-2015, 09:57 AM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
silicone spray lube or wd40 or deep creep will aid in slipping rubber parts over metal
Old 09-22-2015, 09:59 AM
01tl4tl's Avatar
thats not how to clean the EGR SYSTEM!!
dont know who told you just the valve for it
That job requires removal of the complete intake manifold from the engine,
and to the workbench for cleaning with 3 cans carb cleaner and a wire coat hanger
= to poke crud free thru the length of manifold- thru the manifolds internal egr passage
See diy section for info
08KBP_VA
10-22-2019 01:55 PM
rcs86
08-02-2016 06:52 PM
Jinkazetsukai
11-21-2015 05:28 PM
fifer16
1G RL (1996-2004)
10-05-2015 10:12 AM
Quick Reply: Intake troubles
