oil in sparkplug well
Old 11-22-2014, 04:46 PM
drolds72's Avatar
Front, middle sparkplug well was coated in oil, probably over an ounce in there. Neighboring plug wells were dry. Looks like there is a seal that is in between the top of the tube and the valve cover. After reading through the procedure in the service manual, I could not find any reference to a seal at the bottom of the tube. My question is, is the only seal on the top, or do I have to remove the valve cage from the head to access seals at the bottom of the tube? Anybody do this yet? I see the intake has to be removed but it seems pretty straight forward...
Old 11-22-2014, 10:39 PM
oo7spy's Avatar
Received 7,244 Likes on 4,855 Posts
That's the plug that ejects on the J35. Be sure to torque that to spec.
Good luck finding your answer.
drolds72 (11-23-2014)
Old 11-23-2014, 07:29 AM
Received 16,260 Likes on 11,971 Posts
in this picture you can see the spark plug seal in the lower left hand corner.
I had lots of trouble of removing them and installing them.
I found a pretty easy way.
insert flat head underneath seal and twist.
Be sure to remember or take note of how they seat/sit.
I destroyed 3 seals because I put them on backwards and the sharp aluminum WILL cut them up if installed incorrectly.
The following 3 users liked this post by justnspace:
drolds72 (11-23-2014), Nersh7 (12-03-2014), oo7spy (11-23-2014)
Old 11-23-2014, 07:37 AM
FYI; I removed the heads from my car and didnt see or notice a seal/gasket at the bottom of the heads, where the spark plugs are.
Plus that was a lot of work to do.
it would be beneficial for you to tear into at least the valve cover to inspect that #5 seal.
Old 11-23-2014, 07:38 AM
the Spark plug spec's are:
13/lbs of torque WITH lube
or 21-23lbs without
The following 2 users liked this post by justnspace:
Old 11-23-2014, 09:40 AM
drolds72's Avatar
I had just read that thread, and that is exactly why I had decided to check it- when I did the scheduled change it was loose by a full turn...
oo7spy (11-23-2014)
Old 11-23-2014, 09:42 AM
drolds72's Avatar
Awesome- that is exactly the info I was looking for. I might just change both sides once I get the intake off....
did you replace all the intake gaskets, or were you able to reuse any?
Old 11-23-2014, 10:38 AM
my spark tube gasket/seals were all good.
I just decided to paint my valve cover and originally, i thought I would have to bake them...rendering the seals useless.
but as I researched i found that I didnt have to bake the valve covers.
it was too late, since I had tried to pry them out without figuring out how to.
I destroyed them by trying to uninstall them. the sharp aluminum edges are BRUTAL to soft rubber
at that point, I was all in and had to learn how to uninstall and install them properly.
and now im passing on the info to you, so you dont destroy them.
Old 11-23-2014, 10:40 AM
oh shit, i just realized that wasnt the question you asked.
Old 11-23-2014, 10:41 AM
<-------------friend blew my engine, so I changed the heads.
i bought all brand new gaskets from rock auto.
but if i were you, I would re-use the intake manifold gasket.
just inspect it and make sure that it is re-usable.
as Ive taken my intake manifold apart so many times, I just re-use the gaskets
Old 11-23-2014, 05:50 PM
drolds72's Avatar
finished. pretty straight forward. I had a seal puller that I used to get old seals out of their bores. I just did the front bank. it was tricky to get that tube thru the seal without cutting it as you mentioned- not sure how the rear bank would have gone...
Old 11-23-2014, 08:03 PM
oo7spy's Avatar
Time for a beer!
Old 11-23-2014, 08:05 PM
oo7spy's Avatar
What question did you answer? (Sorry, I'm no good at Jeopardy.)
Link?
Old 11-23-2014, 09:16 PM
drolds72's Avatar
Link?
the question was, if I had to replace gaskets when I removed the intake manifold and its cover- Nope! Saved me $40
Old 11-24-2014, 08:33 AM
right, i thought we were still on the spark plug tube seals.
but we had moved on to intake manifold gasket.
Great Job, sir!! I didnt have a seal puller.
if anyone wants to read my engine ordeal, you can read here
https://acurazine.com/forums/problem...32-j37-915065/
drolds72 (11-24-2014)
Old 11-24-2014, 07:31 PM
drolds72's Avatar
Oh man- that bruise in the center of your chest is priceless! The fact that you beat the bolt just makes it a badge of honor...
justnspace (11-25-2014)
Old 11-25-2014, 07:17 AM
HEAVY_RL's Avatar
Received 1,038 Likes on 844 Posts
That tank top and manicure are priceless.
Old 11-25-2014, 07:19 AM
HEAVY_RL (11-25-2014)
IBankMouse
06-13-2020 12:53 PM
spudweb
05-22-2016 02:39 PM
Thuneau
10-03-2015 04:19 PM
jubikej
1G RDX Problems & Fixes
09-30-2015 01:13 PM
Boraxo
1/2G MDX (2001-2013)
09-29-2015 04:35 PM
Quick Reply: oil in sparkplug well
