oil in sparkplug well
Front, middle sparkplug well was coated in oil, probably over an ounce in there. Neighboring plug wells were dry. Looks like there is a seal that is in between the top of the tube and the valve cover. After reading through the procedure in the service manual, I could not find any reference to a seal at the bottom of the tube. My question is, is the only seal on the top, or do I have to remove the valve cage from the head to access seals at the bottom of the tube? Anybody do this yet? I see the intake has to be removed but it seems pretty straight forward...
That's the plug that ejects on the J35. Be sure to torque that to spec.
Good luck finding your answer.
drolds72 (11-23-2014)
in this picture you can see the spark plug seal in the lower left hand corner.
I had lots of trouble of removing them and installing them.
I found a pretty easy way.
insert flat head underneath seal and twist.
Be sure to remember or take note of how they seat/sit.
I destroyed 3 seals because I put them on backwards and the sharp aluminum WILL cut them up if installed incorrectly.
did you replace all the intake gaskets, or were you able to reuse any?
I just decided to paint my valve cover and originally, i thought I would have to bake them...rendering the seals useless.
but as I researched i found that I didnt have to bake the valve covers.
it was too late, since I had tried to pry them out without figuring out how to.
I destroyed them by trying to uninstall them. the sharp aluminum edges are BRUTAL to soft rubber
at that point, I was all in and had to learn how to uninstall and install them properly.
and now im passing on the info to you, so you dont destroy them.
<-------------friend blew my engine, so I changed the heads.
i bought all brand new gaskets from rock auto.
but if i were you, I would re-use the intake manifold gasket.
just inspect it and make sure that it is re-usable.
as Ive taken my intake manifold apart so many times, I just re-use the gaskets
finished. pretty straight forward. I had a seal puller that I used to get old seals out of their bores. I just did the front bank. it was tricky to get that tube thru the seal without cutting it as you mentioned- not sure how the rear bank would have gone...
Time for a beer!
right, i thought we were still on the spark plug tube seals.
but we had moved on to intake manifold gasket.
Great Job, sir!! I didnt have a seal puller.
if anyone wants to read my engine ordeal, you can read here
https://acurazine.com/forums/problem...32-j37-915065/
drolds72 (11-24-2014)
justnspace (11-25-2014)
IBankMouse
06-13-2020 12:53 PM
