Parking sensor 'beep' volume?
See the last page of the installation instructions
http://acura.bernardiparts.com/Images/Install/2013_TSXWagon_BackUpSensors_BII13471.pdf
Thanks for this! Will check with my dealer, not sure I want to pull apart the panels to find the control units.
I suspect there - just like the Acura accessory sensors, but it isn't software based. On the accessory ones the volume is adjusted on the module itself, so it is a trip to the dealer.
Just go to the dealer and tell them that the volume is too low.
Did you read the thread? It looks like you have to adjust the volume on the control module. No adjustments available from the drivers seat.
Of course I read it. The responses were just not that definitive. The document posted is for back-up sensors on a TSX. I was asking if there was new information that someone might know for the RDX specifically.
I don't see any suggestion our RDX is different from what is used in the TSX. Very likely the exact same system and adjustment method.
fafpak
60
03-15-2021 11:42 PM
