Got my 01 CL S yesterday
Old 02-11-2010, 03:12 PM
  #321
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,144 Likes on 4,811 Posts
One step forward.....2 steps back
Old 02-11-2010, 04:05 PM
  #322
GO RANGERS!!!!!!!!!!!!!!!
e30cabrio's Avatar
Received 1,775 Likes on 1,234 Posts
Got the rest of the parts, now I just need a motor.
Old 02-11-2010, 05:44 PM
  #323
e30cabrio's Avatar
The General Manager will not waive the 50.00, the Production Manager has not responded to the "request" to expedite the dismantling of the vehicle the motor I need is in & I am feeling a need to call corporate in Chicago.
And people wonder why businesses in America fail.
Old 02-11-2010, 05:48 PM
  #324
civicdrivr's Avatar
and good luck.
Old 02-12-2010, 11:13 AM
  #325
e30cabrio's Avatar
WHO HOO!
The guy from LKQ just called, they got the motor out yesterday, QC'd it & it will be in my mechanic's possession between 12 & 3pm TODAY!
They are not charging the 50.00!
I will drop the car off Monday at 9am and should have it back by Wednesday!
I was really beginning to think they were blowing me off.
This reaffirms my faith in businesses, I was thinking they just don't care.
Old 02-12-2010, 03:35 PM
  #326
civicdrivr's Avatar
Nice!
Did you get an AFR gauge yet?
Old 02-12-2010, 04:17 PM
  #327
e30cabrio's Avatar
The engine has landed!
I dropped the parts off & he is installing them, I drop the car off Monday at 9am!
Old 02-12-2010, 04:45 PM
  #328
3.7L Nitrous Breathing CL
richardparker's Avatar
I haven't been following this thread.
Is that a mdx motor?
Old 02-12-2010, 04:54 PM
  #329
e30cabrio's Avatar
04 Odyssey J35A4. Basically a 3.5 Type S motor.
It's getting new seals, belts gaskets, ETC. My headers, 09 IM, pulleys etc & going in.
Came from an Ody that was totaled last week with 53k.
Old 02-12-2010, 04:59 PM
  #330
Direct swap ?
What type of gains do you plan to see swaping motors with your
parts ?
Old 02-12-2010, 05:03 PM
  #331
e30cabrio's Avatar
Just the Castings for the motor mounts need to be taken from my motor & attached. (Per NVA-AV6 & I believe him!)
He says I should see significant increases at the wheels in HP & Torque. My motor runs great but has 181k, it's nearing the TB service so I figured why not get a fresh motor?
The old motor will goon a stand & I'll tear it down & see if it is ok to build. I am sure it is since the car was pretty quick. Then I'll slowly build it.
Old 02-12-2010, 05:06 PM
  #332
B A N N E D
friesm2000's Avatar
, it's never good for a motor to just sit around
Old 02-12-2010, 05:10 PM
  #333
e30cabrio's Avatar
LKQ got it on Wednesday, they said it was totaled the week before. I saw the engine in the van Wednesday.
Barely had a vacation & going in a much lighter vehicle I am sure it'll be thrilled!
lol
Old 02-12-2010, 05:21 PM
  #334
B A N N E D
friesm2000's Avatar
yeah for being totaled recently, i would proably believe that especially depending on the yard, most seem to pull the motor right away, so it can be sold easily (faster since it is already removed so don't have to wait for it to be removed)
only thing it that it might have taken a couple of weeks though for the insurance and such to process it, and buy it then sell it, but ethier way it proably has only been sitting for a little while compared to some motors
Old 02-12-2010, 05:27 PM
  #335
B A N N E D
friesm2000's Avatar
also at a bare minimum make sure the prefill the oil filter before they start it up, so it can get pressure as soon as possible, since every thing has basically drained away from sitting for weeks (even better would be to actually put pressurized oil through the oil sender port, and preoil the motor, but not many can actually do that though
Old 02-12-2010, 07:36 PM
  #336
CollinCL's Avatar
I'm excited just reading this can't imagine how you're feeling lol. I think I'm gonna follow suit and go through with those KONI yellows. Keep the pics/updates coming!
Old 02-12-2010, 08:32 PM
  #337
3.5 psi
gnuts's Avatar
are the heads and intake manifold exactly the same as the J32?
This is a good option for getting a 3.5. Much less work involved. So for the guys who open up the engine and put in different rods and pistons...they are just adding a bit more stroke right...so a little bit more power?
Old 02-12-2010, 08:37 PM
  #338
e30cabrio's Avatar
I am 99% sure it is the same except displacement. I know the IM is the same as the one I replaced with the 09.
Old 02-12-2010, 08:41 PM
  #339
Is their a complete motor and trans pull,That would be a direct drop in that would perform better than the clp auto setup.
A 1 piece shot deal would be sweet.
Not trying to thread jack, just curious.
  #340
B A N N E D
friesm2000's Avatar
yes the manifold is the same, but the heads are different, just look up the valve size; ly iirc smaller too then the J32A2
Old 02-12-2010, 08:42 PM
  #341
e30cabrio's Avatar
No, the heads are the same.
Old 02-12-2010, 08:43 PM
  #342
3.5 psi
gnuts's Avatar
will you dyno? I'd love to see some #'s. This seems like such a simpler way of doing a 3.5. Might not get you quite the same power if you added RL pistons, but still a very nice power increase. Good job!
Old 02-12-2010, 08:46 PM
  #343
B A N N E D
friesm2000's Avatar
just means it is better for FI
Old 02-12-2010, 08:52 PM
  #344
civicdrivr's Avatar
The Odyssey motor does not use the same intake manifold.
Old 02-12-2010, 08:53 PM
  #345
e30cabrio's Avatar
I will try to dyno. No promises.
Civic is right, no IMRC on the IM, I know the heads are the same.
Old 02-12-2010, 08:56 PM
  #346
B A N N E D
friesm2000's Avatar
a little different, but the same basic mainfold though, it might be a Preminuim manifold actually with no runner control, idk
Old 02-12-2010, 08:59 PM
  #347
B A N N E D
friesm2000's Avatar
try this:
Edit: The correct valve dimensions now stand as follows: incl. J30A4/J32A4
J30A1 '98-02 AV6: 34mm/29mm (intake/exhaust)
J30A4 '03+ AV6: 35mm/30mm
J32A1 '01-03' TL/CL: 34mm/30mm
J32A2 '01-03 TL-S/CL-S: 36mm/30mm
J32A4 '04+ TL: 35mm/30mm
J35A1 '99-01 Odyssey: 34mm/29mm
J35A4 '02-04 Odyssey: 35mm/30mm
can't seem to find that thread, but found it qouted in another thread though
indeed different sized valves, so different heads (but they do more then likely come from the same casting though, just that the final machineing is different)
Old 02-12-2010, 09:03 PM
  #348
e30cabrio's Avatar
I found a data sheet that showed them as the same, here I'll fix it for you:
J35A4 '02-04 Odyssey: 36mm/30mm
Old 02-12-2010, 09:07 PM
  #349
B A N N E D
friesm2000's Avatar
then tell them to fix it in the faq or where ever that thread is
Old 02-12-2010, 09:36 PM
  #350
e30cabrio's Avatar
http://www.hondatuningmagazine.com/t...s_engines.html
Honda's J-Series: Just The Facts
The J-series is the successor to Honda's ubiquitous V-6, the C-series. First put into the '97 CL and '98 Accord, it's since unofficially became Honda's workhorse. Much like Nissan's VQ, you'll find the J in just about everything. The big difference between the Js and Cs is their angles. The C-series, which includes early Accords, the Legend, and the NSX, features 90-degree-opposed cylinder banks. The J-series measures in at a more compact 60 degrees, which means the heads are closer together and the overall package is smaller. Although there are rare homologations like the J25, the U.S. has only seen variations that range from 3.0 to 3.7 liters. In short, the J-series is excellent. They're all four-valve-per-cylinder, SOHC, configurations with VTEC on their intake sides. They have open-deck blocks with cast pistons and forged crankshafts; some even have forged rods. Prior to the latest 3.7-liter TL SH-AWD engine, they all had 89mm bores with the displacement discrepancies coming from stroke. The Type S engines have the best cams, but the secret is that the J35s feature the same heads and cams as the J32A2 Type S and swapping them over to a non-Type S J-series is entirely doable.
Old 02-12-2010, 09:40 PM
  #351
B A N N E D
friesm2000's Avatar
, first of all never mentions the valve size, and second it just says j35's and not which ones exactly
and yes cams are the same between the A2 and the A4, same part number
Old 02-12-2010, 09:45 PM
  #352
e30cabrio's Avatar
Buy one of each measure the valves, prove it one way or the other OR STFU.
Old 02-12-2010, 09:47 PM
  #353
B A N N E D
friesm2000's Avatar
f*** edit time limit, but anyways:
they also never happen to mention like the newer engines with the single exhaust port, so that comment is a little too generiac for me
Old 02-12-2010, 09:50 PM
  #354
e30cabrio's Avatar
I reject any reality that might detract from my current euphoria and replace it with sunshine, puppies & rainbows of my design, IE bigger HP & TQ from my soon to be installed J35A4.
Worst case I swap the heads after I have the S heads ported polished & rebuilt.
Old 02-12-2010, 09:52 PM
  #355
B A N N E D
friesm2000's Avatar
btw if you happen to be looking at part numbers, it looks to be the same cylinder heads (and cams) as the A1 in the preminuim model and NOT the type-S
try http://www.hondapartsunlimited.com cause they have part numbers for both honda and acura
edit, can't tell the heads, same part # comes up for both the J32A1 and A2, so more then likely same casting, just different machineing
Old 02-12-2010, 09:54 PM
  #356
B A N N E D
friesm2000's Avatar
no arguement about that, with the lower torque band
Old 02-12-2010, 10:01 PM
  #357
B A N N E D
friesm2000's Avatar
nvm about that see newer post about it, above this one
Old 02-12-2010, 10:05 PM
  #358
civicdrivr's Avatar
From what I have found around the net is the intake valves are indeed different. If you want to run the Type S heads on the J35A4 block you need RL pistons otherwise you will bend valves.
Other differences:
-bore and stoke (89x86 for the J32A2 vs 89x93 for the J35A4)
-compression ratio (10.5:1 for the A2 vs 10:1 for the A4)
Anyone know if the rods and crank in the A4 are forged?
Old 02-12-2010, 10:23 PM
  #359
B A N N E D
friesm2000's Avatar
Other differences:
Old 02-12-2010, 10:39 PM
  #360
civicdrivr's Avatar
Pffft, you're useless
Quick Reply: Got my 01 CL S yesterday
