6-speed engine torque damper installed
#241
yeah, but the poly mounts make the car feel like a washing machine with all the vibrating...lol
dont know why everyone is getting civic dampers when they make them for our cars?
http://cgi.ebay.com/ebaymotors/Ingalls-Stiffy-Engine-Torque-Damper-CL-TL-Accord-_W0QQcmdZViewItemQQhashZitem20b37f6072QQitemZ14045 0422898QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccesso ries
#242
Whats up with RDX owners?
Because thats the Stiffy mount, which mounts from the passenger side strut tower to passenger side mount bracket. There is a kit specifically for our car.
The torque dampers we are talking about in this thread replace the two dampers that attach from the block to the subframe. There is no kit specifically for our car, hence the reason for the Civic dampers (or any others with the same length).
AARONSredTYPE-S (06-21-2011)
#244
i will replace the back, but if the side mount is just as good, then i will just do that, whatcha think?
#245
When I replaced my engine mounts at 115K or so I was seriously going to go the NRG route. However, I decided to get OEM instead because if the issue of the NRG damper coming loose on my front mount ever occurred, I would have to remove the S/C unit just to get at it. I'm getting old, hehe, and just did not want to F#ck with it again.
Then when the Ingalls damper kit was developed (thanks to friesm2000) I jumped on it and it has made a huge difference (at least in my case) when used with the new OEM mounts/dampers. I have it set on the stiffest setting and could not be happier.
#250
3.5 psi
The 6 speeds have engine torque dampners front and rear. The autos didn't but maybe you could add them. Ppl replaced them with nrg dampners meant for an old civic. Those should help keep that monster engine planted.
Humberwho (05-16-2015)
#251
I have wondered how the xlr8 mounts would hold up without the dampers.
I consider the dampers as protection for my mounts. Mounts are holding up well, so not gonna change my setup. It works great for me.
orkoTL
4G TL Problems & Fixes
107
09-28-2017 09:12 AM
03, 172mm186mm, 50831s3ma02, 50845s3ma01, acura, acurazine, california, cl, dampener, damper, engine, nrg, speed, speedenginefresno, torque
