B codes?
Old 02-11-2012, 06:17 PM
Jase13's Avatar
B codes?
Hello everyone. I am new to the Acura, well owning one atleast. I worked for Acura as a Painter for three years but I have always been a VW owner. I finally got tired and made the switch to the most solid car on the road in my opinion. I bought it today, it is a 2007 TL and I love it. Only issues I have noticed are ALL the b codes popping up on the dash. Only thing I am aware of is the trunk was not popping and they had to get the radio code before I would purchase it. They did but now these codes are popping up and my scanner shows nothing so I am assuming they are minor codes. If anyone could help I would greatly appreciate it. Thank you.
Old 02-11-2012, 06:24 PM
6th Gear
monazzim's Avatar
Here's something I found once. Hope it helps.
Maintainence Main Items
A=
Replace engine oil
B=
Replace engine oil and oil filter
Inspect front and rear brakes
Check parking brake adjustment
Inspect these items:
-Tie rod ends, steering gear box, and boots
-Suspension components
-Driveshaft boots
-Brake hoses and line (including ABS)
-All fluid levels and condition of fluids
-Exhaust system
-Fuel lines and connections
Maintainence Sub Items
1=
Rotate tires
2=
Replace air cleaner element
If you drive in dusty conditions, replace every 15,000
miles (24,000 km).
Replace dust and pollen filter
If you drive primarily in urban areas that have high
concentrations of soot in the air from industry and
from diesel-powered vehicles, replace every 15,000
miles (24,000 km).
Inspect drive belt
3=
Replace transmission fluid
Driving in mountainous areas at very low vehicle
speeds or trailer towing results in higher
transmission and transfer temperatures. This
requires transmission and transfer fluid changes
more frequently than recommended by the
maintenance minder. If you regularly drive your
vehicle under these conditions, have the transmission
and transfer fluid changed at 60,000 miles (100,000
km), then every 30,000 miles (48,000 km). (For A/T
only.)
4=
Replace spark plugs
Inspect valve clearance
5=
Replace engine coolant
NOTE:
Inspect idle speed every 160,000miles (256,000 km).
Adjust the valves during services A, B, 1, 2, or 3 only if they are noisy.
Independent of themaintenancemessages in themulti-information
display, replace the brake fluid every 3 years.
Old 02-11-2012, 06:26 PM
3G TL/2G MDX Owner
TLtrigirl's Avatar
where are these B codes popping up exactly??? these maybe maintenance codes. does it say "service due" or "service due soon" with a B and possibly a number?? pic???
Old 02-11-2012, 07:08 PM
Jase13's Avatar
They are showing up on the dash.
They are:
b1005 10
b1006 10
b1007 10
b1008 10
b1010 10
b1011 10
b1830 95
b2204 97
b2207 97
b2208 97
b2209 97
Old 02-11-2012, 07:12 PM
3G TL/2G MDX Owner
TLtrigirl's Avatar
...that's a new one. never heard of this. definitely NOT a maintenance code.
any CELs on??
Old 02-11-2012, 07:17 PM
Received 16,260 Likes on 11,971 Posts
Originally Posted by KN_TL
Check out this thread. Looks like the dealer may be able to help you clear the codes if it is something the installer did. You should also make sure they used a relay if they used the fog light circuit to switch the HID's.
https://acurazine.com/forums/3g-tl-problems-fixes-114/multiple-mid-error-messages-after-stereo-install-644787/
B1010 MICU Lost communication with Door Multiplex Unit (panic message)
B1008 MICU Lost communication with Gauge Control Module (A/T Message)
B1006 MICU Lost communication with Door Multiplex Control Unit (door lock switch message)
B1005 MICU Lost communication with Relay Control Module
B1011 MICU Lost communication with Gauge Control Module (VSP/NE Message)
B1007 MICU Lost communication with Combination Switch Control Unit (Headlight Switch Message)
B1060 Relay Control Module Lost Communication with Gauge Control Module (VSP/NE Message)
B1726 Display Control Unit Lost Communication with Climate Control Unit
B1800 Communication Bus Line Error (BUS Off)
B1843 Power Seat Control Unit Lost Communication with Other Unit's (UART Communication Error 2)
B1831 Right Mirror Vertical Sensor Malfunction
B1833 Left Mirror Vertical Sensor Malfunction
Do all these things work? That's a lot of comm issues. Hopefully just happened intermittently and the codes are locked until cleared. Otherwise you may be in for an expensive fix.
the codes are ELECTRICAL.
engine codes are designated with a P. you have B codes. ELECTRICAL problems.
As KN_TL pointed out, it could have severe effects on your car.
something isnt right. and since you recently got the HIDs installed, it COULD be the source.
you need to go over all the wiring.
re-checking EVERything.
from this thread:
https://acurazine.com/forums/3g-tl-problems-fixes-114/help-guys-what-do-these-codes-mean-video-inside-847048/
The following 2 users liked this post by justnspace:
Jase13 (02-11-2012), TLtrigirl (02-11-2012)
Old 02-11-2012, 07:20 PM
3G TL/2G MDX Owner
TLtrigirl's Avatar
thanks justn!! figured you pop in here eventually. i just learned something new today.
Old 02-11-2012, 07:30 PM
Have the dealership clear the codes.
Old 02-11-2012, 08:47 PM
KN_TL's Avatar
Bought it today? Was it from an Acura dealer, other dealer or private sale.
With that many electrical codes, I would try to take it back. 3G TL's are very complex electrically and I would be very wary of this. Unless you can get a lifetime warranty for electrical issues with roadside service.
Old 02-11-2012, 10:12 PM
**WhItE-aNgEl**'s Avatar
These codes are becoming common now wtf? I'll let you know Tuesday jase when they fix my car why I was getting the same codes your getting
Jase13 (02-12-2012)
Old 02-12-2012, 07:13 AM
Jase13's Avatar
I bought it from an Independent Dealer and also purchased a 25,000 mile warranty which covers close to everything. I drove the car several times before buying it and it was fine. When I came to pick the car up they were there and like I said, I beleive they popped up because they fixed whatever was causing the trunk not to pop (fuse maybe?) and they had to get the radio code for me from Acura to set it so I am thinking whatever they did to get those two issues fixed is what caused them to pop up. I don't think they are major issues because everything still works fine but they are annoying to stare at while driving more than anything.
Old 02-13-2012, 01:36 PM
MikeSoper's Avatar
Remember, if you changed your timing belt at 100k or so they surely changed your coolant also. So you can ignore a B5 service code.
Old 02-13-2012, 03:04 PM
Jase13's Avatar
Thumbs up
Got it! They are codes for the Navi and also because they put a different actuator from a different year on my trunk when they changed it. Sweet! Thanks for all your help folks. Also if anyone has these codes pop up, let me know and I will look them up on AllData at work. Thanks.
Old 06-15-2014, 02:25 PM
I like turtles
luckyjakob's Avatar
I've been having issues with my TL as well and got some of these code:
B1010
B1005
B1006
My alarm has been triggering in heavy rain and this is all the dealer was able to pull. Very frustrating!
hrglas (08-17-2018)
Old 05-02-2015, 11:16 PM
king420king's Avatar
hey mine just pop up too
Maybe u can help me Learn more about my car
Old 12-20-2016, 11:22 AM
FMG
FMG's Avatar
I have every single one of those codes on my dash. & my car runs like a champ. The blinking annoys me, but like you a thorough comouter scan showed nothing serious
Old 08-17-2018, 06:41 PM
2007 NBP TL
hrglas's Avatar
B1010
B1005
B1006
Did you ever figure out what was going on with these codes? I just experienced this same thing last night, and into today! Rain, plus alarm trigger, and these display codes!
Old 09-07-2020, 04:06 PM
9th Gear
Semperbenjamin's Avatar
Holy Revival
plug under the steering wheel. Causes that weird “b” code to continually flash on the mid.
Old 02-19-2024, 11:41 AM
Brandt24's Avatar
What did you have to do to fix this issue?? I’m getting the exact same codes due to something within the Navi system but don’t know how to get rid of them.
Jamus22
06-11-2023 10:08 AM
MilanoRedDashR
10-02-2015 10:49 AM
thegipper
09-28-2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
09-28-2015 12:33 PM
mars
09-28-2015 11:03 AM
Quick Reply: B codes?
