Main Trunk Switch Fell Apart - Need pics
Old 06-26-2015, 05:57 PM
3rd Gear
brighamYoungMoney's Avatar
I just played around with the iSimple for the third time and messed up the main trunk switch putting the glovebox back together. I'm not sure how it happened but I ended up with the two pieces in the picture. If I recall correctly, this piece with the red on it is supposed to be inside the main switch, or am I mistaken? The thing is I have absolutely no idea how it popped out of it if that is the case, is there another piece I am missing that broke off? Any help/pics of what the main switch is supposed to look like would be appreciated.
If I end up not being able to get the piece back in, can I solder the back of the switch to close the circuit?
Old 06-26-2015, 09:40 PM
JMiles_T's Avatar
I can't help you with a picture now, but if you need to replace it, the part number is 35810-SEP-A01
Part Numbers for interior components
Old 07-05-2015, 02:47 AM
Duronn's Avatar
If it popped out with the cover on, then you should be able to find out where it popped out from. If not, then carefully remove the cover w/o breaking the plastic tabs and place it back in. You don't need a picture to figure out how it goes together, look at the terminals, its an open and closed switch, just like a light switch.
mada51589
05-03-2022 08:54 PM
VA2000TL
10-02-2015 08:26 AM
Skirmich
09-15-2015 06:41 PM
PortlandRL
09-14-2015 12:01 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
Quick Reply: Main Trunk Switch Fell Apart - Need pics
