Sponsored by: DashLynx
2010 acura tl awd oil life vs. Oil consumption
Old 02-07-2017, 08:37 AM
vaughanml2's Avatar
Hey all,
My low oil level indicator came on yesterday evening. When I check my oil life on my dash it is still displaying 50%. I have gone about 3800 miles or so since my last oil change. About 500 over what the sticker says on the windshield. I am under the impression the "oil life" gauge on my dash is the life of the filter? Am I ok to add a few more quarts of oil and ride another thousand miles? Thanks all!
Old 02-07-2017, 08:43 AM
Received 16,260 Likes on 11,971 Posts
oil life % is a calculated formula. it uses; start-ups, engine revolutions and other factors to figure out the life of the oil.
which is completely independent of oil consumption.
yes, if your engine is consuming oil, you can add oil to where it comes up below the max line on the dipstick
which means, who ever is changing your oil according to the sticker is CHANGING it early...
but that might not be a bad thing, as you can monitor oil consumption by reading the dipstick and catching before the engine goes dry
Old 04-23-2019, 09:37 AM
Pfinn's Avatar
Help!
Got my letter about the oil consumption problem, took it to my Acura dealer and he said he would start the process after the oil change then inform me that I have an oil leak and he estimated the repair bill at $1850 and I have to do that before he can start the oil consumption test! Wtf! So before he can fix the problem and to even see if I have an oil consumption problem they want $1850 to repair the oil pump leak? Time for a lawyer perhaps?
Old 04-23-2019, 09:58 AM
The inconvenient truth
dopeboy1's Avatar
Heres the thing, if you car does have an oil leak then how can they do an accurate oil consumption test? There would be no way to tell what oil has been burned (consumed) or what oil has been leaked. And of course the dealership repair of an oil leak will be expensive.
I would take it to another dealership and make no mention of the leak and just ask for an oil consumption test and see what they say. Or take it to an independent mechanic and see if they can confirm there is an oil leak, if there is they will likely want much less than a dealership to fix.
justnspace (04-23-2019)
Old 04-23-2019, 10:14 AM
Pfinn's Avatar
Thanks, yes that’s what I was thinking I will take it to another dealership with the paperwork for the oil consumption test and see what they say I take my car to the same dealership every single time and I have a hard time believing that this is the first time they’ve seen the oil leak now that I’m requesting the test!!! Did I mention it’s a 2012 MDX with less than 70,000 miles
Old 01-14-2020, 12:58 PM
Mistwrt's Avatar
2013 MDX 86K consumed all the oil and engine is now damaged and the dealer said it is my fault. I took it to them as soon as a light came on and they say it is not covered and will not pass the consumption test. Live in SF Bay Area if anyone is interested in the car or has a recommendation on what to do?
Old 01-14-2020, 02:02 PM
dopeboy1's Avatar
In light of how much oil these engines can burn its my opinion they should help you out. But at the same time I know they wont. Why you ask?
Because in your owners manual it tells you to check the oil level once for every tank of gas. If you had done this then there would be no engine damage. Therefore they are right, it is your fault.
dregsfan (01-15-2020)
Old 01-21-2020, 07:38 AM
7th Gear
jgalloway84's Avatar
I suggest you check your oil bi-weekly and keep it towards the full mark (the top of the markings) to avoid ever getting low. My 2012 TL SH-AWD uses ~1qt per 3500 miles or so. I typically change it around 4k-4.5k on a nice day, regardless of the oil life indicator, and never worry about running low on oil. My indicator is typically around 30% left or so and I reset it with every oil change.
Old 05-20-2020, 05:08 PM
aphmd's Avatar
https://www.settlement-claims.com/oilconsumption/
Old 09-22-2021, 02:49 PM
8th Gear
andreyfalcon's Avatar
Has anyone tried using different types of oils?
I heard the rumor that Walmart oil helps (Super Tech advanced full synthetic)
I added 1qt to my 2010 mt shawd and for almost a month no consumption.
Can anyone confirm this?
Old 09-22-2021, 05:02 PM
dopeboy1's Avatar
I also would love for someone to confirm that Walmart has magic oil.
Old 09-22-2021, 09:28 PM
dzionny_dzionassi's Avatar
no way
Old 09-22-2021, 10:31 PM
altair47's Avatar
Clogged oil piston rings can be only flushed or changed, all other manipulations are just a short-term solution to the problem.
rafiki121
4G TL Problems & Fixes
05-20-2017 06:13 PM
dadon
11-02-2010 01:08 AM
youscott
04-15-2008 09:24 PM
Moodist
11-11-2004 12:09 PM
Quick Reply: 2010 acura tl awd oil life vs. Oil consumption
